Simplify your intake system: one 4 barrel!
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Almost Banned Once
That is awesome... Would be something to play around with a set-up like that.
I bet it would go hard... But it doesn't look right for a 911 engine bay so that would be reason enough for some people to bag the idea. Good find
Almost Banned Once
It's worth $200 for the intake pipes alone... I love the custom CIS box base
I saw one of these setups years ago, but this one is a bit better developed.
Senior Advisor
I think that carb would ice up if you don't heat up the plenum and the tubes
08 Cayenne Turbo |
Due to the distance from the accelerator pump, the engine might experience turbo lag, but without the turbo.
Sherwood |
Senior Advisor
kinda cool, and cheap!!!
08 Cayenne Turbo |
Dog-faced pony soldier
Tempting... I wonder about putting that on my 2.7... Hmmm. A heck of a lot cheaper than either Webers or (yikes!) PMOs. Ya know what "PMO" stands for right? "Pay More Out".
![]() I have a spare CIS box downstairs. That's giving me some ideas... Surprised more people don't try stuff like this. Seems almost idiotically simple and bulletproof.
A car, a 911, a motorbike and a few surfboards Black Cars Matter Last edited by Porsche-O-Phile; 03-12-2009 at 02:40 AM.. |
Eye of the Toiger
that is a damn good idea
http://www.aircooled.com.au 1973 911 RSR clone powered by 77 3.0 turbo |
Reversing technology, just like NASCAR. There are lots of reasons not to.
Rob |
(the shotguns)
the neat thing about it isn't the cost savings but rather the need to only tune one mixture, etc.
not to mention a sniffer machine at the tail pipe would actually mean something!
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
Almost Banned Once
All good comments but how would it perform?
Has anybody used a similar setup? |
(the shotguns)
Doesn't CIS have a common plenum?
I had a single carb on my 914 years ago.....it ran fantastic and no more issue with Fuel Injection.
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
Go Speedracer, go!
Bob Farmer (Farmer's Automotive), here in Indy fabricates a setup just like that. I have seen it on one of his race cars in the shop. He said it flows better than the common setups, and it is cheaper and easier to tune. I wish I had taken a picture when I was in there a few weeks ago getting my mixture adjusted. Someone in the local area has to have experience with it.
1981 SC ROW Coupe |
cycling has-been
the guy in the booth next to me at Hershey last year had one FS & I got to talk to him about it.
Yes on the turbo lag, with lots of gas fumes in the cabin when driving, and he could not get jets small enough to lean it out for sub 3,000 rpm driving. He started out at $250 at 6:30am and was at $25 by 3:30pm with no takers. The carb alone is over $400 new isn't it? Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
I think that might work okay at a constant throttle opening. As for overall operation, I have my doubts. How does each cylinder receive an equal amount of A/F? Thank you.
40 years ago, someone (EMPI?) manufactured a single 4-barrel carb. conversion for the Corvair and it didn't work as well as the factory setup of two single barrel carbs feeding each bank of three cylinders. Summarize what you will out of that bit of history. But time marches forward, and I'm not against any attempts at improvement. Sherwood |
Diss Member
BZZZZZZT... thankyouforplaying...
Holly's are easy to tune, produce good power, come in almost any size, are great for muscle cars, ... ...and suck for dealing with g forces. You can easily set it up for acceleration forces but dealing with forces from all directions will cause float level problems. In practice what you get is: A good sticky set of tires and the engine will tend to flood under hard braking as gas sloshes from the vent tubes into the venturis. To get the lateral acceleration problems under control you have to lower the float level but that causes the jets to tend to uncover from sloshing. The core problem is the float chamber isn't very tall and is rather wide. This doesn't work for hard cornering and braking. Quote:
When you are done messing with it you will end up with a system that cruises great but the float system still won't let you corner or brake.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
AutoBahned
I did that on a bus motor in the 1970s. It works but not nearly as well as some other options.
And... it has been discussed here before. In essence, it has the advantage of being cheaper than some other options, but that is about it. What I like is the cheapo m/c throttle body adaptations that some were playing with. We all know that there are LOTS of wrecked m/c's lying around. Last edited by RWebb; 03-12-2009 at 02:22 PM.. |
If you want an affordable alternative to Webers or PMOs -- get some Zeniths. While they don't have quite as many tuning options as Webers, I'd have to believe that they are certainly better then the Holley in this application given that they were original equipment 911T's for a couple of years.
John '69 911E "It's a poor craftsman who blames their tools" -- Unknown "Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman |
