Motor dies when I open tank to check oil
I've had six 911s since my first '68 911L. As I recall, that with all of them I checked the oil level with the motor idling by reading the dipstick.
I haven't driven my '80SC w/3.6 964 transplant very much in the last ten years, but when I try to check oil level with the motor idling, the motor dies as soon as I remove the oil tank cap. What up, is this normal or am I missing something! Is this a quirk of the 3.6 motor or is something amiss.
Grant
Old 03-16-2009, 06:26 PM
Sounds like you are missing the necessary restrictor in the hose connecting the oil tank to the intake system. This creates a vacuum leak that kills the engine.
Its a $20 part and will fix your problem.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 03-16-2009, 06:49 PM
RETIRED
Joe Bob's Avatar
Too much vacuum....not enuff cowbell.
2012 ML350 3.0 Turbo Diesel
Old 03-16-2009, 07:10 PM
I've looked at the oil hose section on our host's parts pages, and can find no restrictor listed, just the hoses. Where would I find this $20 part?
When I installed the 3.6 motor, I just hooked up the hose from the 3.6 to the existing "80SC oil tank.
Old 03-16-2009, 07:11 PM
chrisp's Avatar
until you get the restrictor you can clamp it with a pair of pliers or a vice grip to keep it from stalling.
'83 SC
Old 03-16-2009, 07:54 PM
chrisp's Avatar
from the parts layout on pelican for the SC it looks to be 930 107 289 00.
'83 SC
Old 03-16-2009, 08:00 PM
Administrator
Jack Olsen's Avatar
This is the part:
It goes in the line that runs from the oil filler neck to the intake (not the one that goes from the crank case breather to the oil tank). On a 3.2, the part number is 930-107-289-00.
Old 03-16-2009, 08:15 PM
Laneco's Avatar
It sure fixed my car, thanks again for the "e-diagnosis" on Butters, Steve! Can't believe that little missing piece would just flat make it stall when you pop the cap. Dang things must run on vacuum!
angela
Hello
Old 03-16-2009, 08:32 PM
Once again you wonderful Pelicans came through! I was beginning to think Alzheimer's was clouding my long term memory about checking oil level! Just was sure the motor shouldn't die when removing tank cap, but was starting to doubt my memory. Big thanks!
Grant
Old 03-16-2009, 08:41 PM
Make Bruins Great Again
Por_sha911's Avatar
Once again, this has been discussed several times. The search button is your friend.
Joe
Old 03-16-2009, 09:02 PM
Senior Advisor
James Brown's Avatar
no one got the cowbell joke! Thanks Mikez. that's a great SNL skit
08 Cayenne Turbo
Old 03-17-2009, 01:09 AM
Ruby911
ruby911's Avatar
I got the cowbell joke, JB. Well placed.
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 03-17-2009, 04:40 AM
toddu's Avatar
Does it matter where in the line this goes (which end, which direction)?
Todd
'81 SC
Old 03-17-2009, 09:43 AM
Zink Racer
Not to be a pain but what is the big deal with flogging people that someone assumes didn't try the search feature to deal with their question? Maybe he did search and didn't come up with the right phrase to narrow down the results enough or hit exactly his topic. Assuming this service has been up for several years wouldn't most all issues have been addressed at some point. What's then the point of asking anything? I for one appreciate the questions. It's interesting to see what's being asked and the answers come forth. I just don't get the constant harrassment by folks who aren't moderators telling people they shouldn't post their questions but then again I may be missing something
Jerry
Old 03-17-2009, 12:00 PM
jhynesrockmtn,
Amen +1
Old 03-17-2009, 12:04 PM
Laneco's Avatar
Todd
I put mine in on the end nearest the tank. I put it in small end first because it was easier to push in that way! Make sure it's in far enough that it allows you to properly reinstall the line.
angela
Hello
Old 03-17-2009, 12:29 PM
Somatic Negative Optimist
Gunter's Avatar
Interesting.
When using the number 930-107-289-00 in the parts window, it brings up info for various models listing it as an "oil pump restrictor" for SC's '81 but as a "line restrictor" for other models.
Oil pump restrictor? Why would one restrict the oil pump?
Also, the diagrams (Pictures) are not clear about location?
The SC diagram shows it on the bottom of the tank. In the S-line maybe?
For other models, it shows it on top but also not very clear.
Try it.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 03-17-2009, 12:45 PM
Do a search- we've talked about flogging people for not searching many times before.
Old 03-17-2009, 12:49 PM
jhynesrockmtn, + 2, quit flogging people whith honest questions. Lynn
lynn, 68 912 coupe, 2011 Cayman base
Old 03-17-2009, 12:55 PM
Hendog's Avatar
That's why I like this forum. I can just browse through the different threads to see what kinds of problems people are exepericing along with the solution.
If and when I have the same problem, a faint glimmer of memory may come on in my mind knowing what the solution is. Or perhaps I'll use the search button looking for this very thread.
It's one of those "whoddathunkit" problems. Unlike "how do I jack up my car?"
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 03-17-2009, 12:59 PM
