Tach Rotation
This is a pretty simple question but figured I'd ask ones who have done it before as I have not. How complicated and difficult is it to rotate the tach in my 69 912. Any steps or advice on the best way to do this would be appreciated. -JWK
Old 03-13-2009, 01:48 PM
you see Arthur...
jasonlee's Avatar
I can't comment on a 69 912, but for my SC, it was very simple. Gentrly pull the tach out, rotate to desired position and pop back in. Took me all of 5 minutes.
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 03-13-2009, 02:24 PM
Ferdinand Magazine
johndglynn's Avatar
Do you mean just physically twist the gauge in the dash (easy) or rotate the face so it displays within the steering wheel? North Hollywood Speedo can do the in-dial rotation:
Sheriff at www.impactbumpers.com
Brand support at classicretrofit.com/tuthillporsche.com
1976 Porsche 911 Carrera 3.0: 'The Orange' - 1981 924 Turbo - 1983 944 Lux - Too many BMW motorcycles
Old 03-13-2009, 02:45 PM
3rd_gear_Ted's Avatar
Yours has been stuck in place for 40 years. Take a long pole with a soft end and work it between the wiring to get @ the back side of the tach. Gently tap around the circumfrence of the tach @ 120 degree intervals from inside the trunk until you sense it pop loose.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 03-13-2009, 02:54 PM
Austin, Texas
roaddog84's Avatar
Shouldn't be too difficult since they are just pushed into place, although that dash looks like it has been touched in the past 40 years, very nice. Interesting design of the numbers where the red-line is at the 12 o'clock position.
What's wrong with it anyway, it looks factory correct?
Old 03-17-2009, 11:31 PM
Austin, Texas
roaddog84's Avatar
Opps, sorry Johndglynn, your dash looks very nice and I see why you wouldn't want to rotate it.
George
Old 03-17-2009, 11:39 PM
Keepin' it Simple...
R_Builder's Avatar
If I recall correctly, your 69's gauges are held in place from the back side with clips and thumb screws (the rubber rings we all know and love didn't start until 70), so before you try this take a look at the back of the gauges from the trunk area and verify how they are held in place...
There should be 2 thumb screws and clips per gauge. Loosen them and the gauge will turn in its hole in the dash. But be careful as there is a thin rubber sealing ring between the gauge and dash that is probably quite dried out and brittle. I would hesitate to turn the gauge in place... probably safer to pull it out far enough to get a good look at the rubber seal, then turn it/rotate it and place it back in the desired location.
-Doug
1968 911R Clone; 11/07-?? (forever the project car )
1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers)
1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home)
1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany)
Old 03-18-2009, 05:23 AM
Ive had a couple '69 912's and the above post is correct. They don't just pull out. You have to reach in from the trunk and remove fasteners from the back. You may have to remove some defroster hoses to get at them.
Seems i remember my 912 speedometer had a glass face when i took it apart. That was over 20 years ago so I'm not sure though.
Old 03-18-2009, 07:47 AM
