hi, where to buy hayden rear sway bar mounts...how much? thnx
Old 05-16-2012, 09:02 AM
hi, my 87 911 ,3.2 carrera oil return tubes leak. has anyone experience replacing?
most important question is how to deal with heat exchanger/ exhaust on driver's side?
a porsche mechanic told me it can be done with a special tool without removing exhaust.
has anyone accomplished this...how?
thnx
Old 05-16-2012, 09:06 AM
RETIRED
Joe Bob's Avatar
Hayden? Isn't he the owner of WEVO?
Welcome to Windrush Evolutions - WEVO - Porsche Products
2012 ML350 3.0 Turbo Diesel
Old 05-16-2012, 09:12 AM
Bland
unclebilly's Avatar
Serious? Holy Crap! I think this is the first time this ever happened...
Oh wait, do a search, I think it happened to to somebody else one time. I think they ended up parting out their car...
Seriously, this is common and there are several documented fixes on ths BBs.
Old 05-16-2012, 08:45 PM
I found this problem on my car tonight, and I'm a little worried! Can anyone let me know whether I can still safely drive with this rear sway bar bracket broken?
Old 05-25-2024, 11:07 PM
Bucketlist's Avatar
Just as an alternative solution the PO of my car had replaced the Sway-bar with a Weltmiester 22mm bar. This is mounted with bolt on bushings. I had to replace these once and found old mustang bushings fit.
1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters.
Old 05-26-2024, 04:04 AM
Still here
pmax's Avatar
The pic appears to show it's just the bolted on brackets falling off, not clear what happened.
Unless that other bracket's about to fail as well, do check, a sedate drive to the shop shouldn't be a problem.
Old 05-26-2024, 11:04 AM
It looks like the bracket has sheared and will mean that the other bracket is taking all of the load, which is then very likely to do the same. It’s safe to drive to your repairer, but that would be all I’d recommend
Old 05-26-2024, 11:42 AM
PCA Member since 1988
Ian, once the bracket comes loose on one side, the sway bar flops around and there is little or no force on the other side.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-26-2024, 02:57 PM
Make Bruins Great Again
Por_sha911's Avatar
Your handling will be different. I would avoid Laguna Seca or Auto-Xing until it is fixed.
Joe
Old 05-26-2024, 06:58 PM
