hi, where to buy hayden rear sway bar mounts...how much? thnx
hi, my 87 911 ,3.2 carrera oil return tubes leak. has anyone experience replacing?
most important question is how to deal with heat exchanger/ exhaust on driver's side? a porsche mechanic told me it can be done with a special tool without removing exhaust. has anyone accomplished this...how? thnx |
RETIRED
Welcome to Windrush Evolutions - WEVO - Porsche Products
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Bland
Serious? Holy Crap! I think this is the first time this ever happened...
Oh wait, do a search, I think it happened to to somebody else one time. I think they ended up parting out their car... Seriously, this is common and there are several documented fixes on ths BBs.
06 Cayenne Turbo S and 11 Cayenne S 77 911S Wide Body GT2 WCMA race car 86 930 Slantnose - featured in Mar-Apr 2016 Classic Porsche Sold: 76 930, 90 C4 Targa, 87 944, 06 Cayenne Turbo, 73 911 ChumpCar endurance racer - featured in May-June & July-Aug 2016 Classic Porsche |
I found this problem on my car tonight, and I'm a little worried! Can anyone let me know whether I can still safely drive with this rear sway bar bracket broken?
Just as an alternative solution the PO of my car had replaced the Sway-bar with a Weltmiester 22mm bar. This is mounted with bolt on bushings. I had to replace these once and found old mustang bushings fit.
Steve 1981 SC Steel Widebody Outlaw in Pacific Blue and Artic White, 930/51 to 3.2l, K27 7006 Turbo, P&P Twin Plug heads, Twinfire Ignition, BLwur, Ruf Intercooler, Powerhaus headers, Zork, CIS Euro FD, 009 injectors, DOD, DP Lid, 044 pump, 930 4 sp LSD, Mocal 44 w/fan, LM2, Brembo, Retroair, Euromeisters. |
Still here
The pic appears to show it's just the bolted on brackets falling off, not clear what happened.
It looks like the bracket has sheared and will mean that the other bracket is taking all of the load, which is then very likely to do the same. It’s safe to drive to your repairer, but that would be all I’d recommend
PCA Member since 1988
Ian, once the bracket comes loose on one side, the sway bar flops around and there is little or no force on the other side.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Make Bruins Great Again
Your handling will be different. I would avoid Laguna Seca or Auto-Xing until it is fixed.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
