spark plugs for modified 2.2
After reviewing posts on the subject, I'm still unclear. Can someone recommend the best plug for:
2.2 with T crank, S pistons & cylinders, E cam, Webers
Street use only.
Mild climate.
I've ordered, but not yet installed, a set of Bosch WP5DC's. Should I put'em in or get some others?
Thanks in advance,
Rob
356robo
70 T Targa
Looking for a 2.2,2.4, or 89 coupe
Old 03-19-2009, 12:57 PM
T77911S's Avatar
put them in. look at them once a week if you drive it regulary. it is better to start cold and move up to a hotter plug if needed.
with carbs, you may find they foul from idle or cold starting, move up a range. its the richness at idle that the fouls plugs.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 03-20-2009, 07:25 AM
Peter Zimmermann's Avatar
NGK BP7ES gapped at .032". Get the car hot, run the revs up, shut it off and pull a plug - if the electrode is light gray you're good to go, you don't want to see chartreuse/light green, then they're too hot.
A lot depends on your combo of ignition timing/distributor, carb venturis/jetting, etc; my recommendation is for a "typical" engine using the parts listed - yours might not be typical (odd deck height, etc.) so always sneak up on the right plugs/fuel mixture.
Keep the Shiny Side UP!
Pete Z.
Old 03-20-2009, 07:40 AM
