Replacement battery
Looking for info on a new battery for my 76 Targa. Optima red top seems to popular but I realize it wont use factory mounts. Any incite is appreciated.
Optimas are good because they don't leak. But, the don't have the highest rating and they are pricey. Buy a group 49 (I think it is) get 850 amps and bolts right up. Exide has a good rating. A lot of places don't carry the groups that fit the 911. The poles are reversed, so a generic won't work unless you want to do cable work.
If you charging system is in good working order, your battery won't leak and mess up your sheet metal. You should treat all that anyway. BTW, welcome to the forum! |
I put an Odyssey 925 in my 76 Targa, (
), using the Rennline kit. It's a quick way to loose 21lbs, and get a battery that won't leak, and can tolerate non-use much better than a standard LA battery.All that being said, I've had good luck with an Optima red-top in my rock crawler.
1976 911S Targa, Carrera bodywork, 3.2l engine. |
Caveman Hammer Mechanic
http://forum.ih8mud.com/diesel-tech-24-volts-systems/162440-fj-bj-mutation.html eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
sudo apt-get purge 930
Optima red here
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Second Optima Red in three years (warranty replacement). Will never get another.
DonMo 1984 911 Carrera Targa 3.2 liter, SSI's, Dansk 2 to 1, Steve Wong Chip Columbia, SC "Go Hokies" |
Almost Banned Once
Odyssey for 6 years... I was so impressed I bought another for my VW Golf (3 years).
I also have a kill switch at the battery. Unless you drive your car everyday this would be a good idea for any car that sits for any length of time. Mine is a "PC925".... http://www.odysseyfactory.com/batteries.html
- Peter |
MBruns for President
I just did this - went with a group 48 battery (eveready)from Sams club for $59 Fit just like the old one - the old one an exide lasted almost 8 years.
I couldn't justify the cost of an optima - although I have two blue tops in the boat.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Batteries
I just put new batteries into my 72 911T, I found Interstate U911, they fit perfect into the boxes and if I would have the original hardware for securing them, they would work perfect.
Posts are covered, so there is no problem with shorting out. I hope so. Fritz |
Nice. I'm a mini-truck guy, but Toyota just the same.
Fritz,
You wrote this post about 5 years ago, but I see you had a similar challenge that I have in 2013. How did you solve the securing issue without the original hardware? PM me if you get this message. Thanks, Tom |
Don't know if you got your answer, but this may help: Mounting an Optima battery
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
if the above link doesn't help this may give you some insight. another battery install thread
- He gave his father "the talk" - Once while sailing around the world he found a shortcut - He taught a german shepard how to bark in spanish He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends. |
another option is to install a smaller (but still compatible) group 48 battery -- at least on carreras, there's apparently a second mounting hole that will secure them and they have the same polarity/post positions as those for the monster oem battery. If you look for an AGM style battery, i believe it will provide similar benefits to the optima as the acid is in a gel state and won't spill/boil out. Search the forums for more info
Just replaced mine on an 84 Carrera using a group 49 Bosch maintenance free battery which fits perfectly with the stock screws and retainers. If you are looking to spend less ($108 installed)! It does weigh 44 lbs though. I think the Optima red top is 31 lbs.
Carquest and NAPA can get the East Penn-Deka 48AGM70 (group 48 AGM..fits fine in the battery location with one of the optional fitting points) for about $158.
I used the Deka to replace my nine year old full sized OEM Porsche truck battery that was in there..man that thing weighed a ton. The Deka was much easier to move around. If your battery ground strap is old enough to vote (or better than 10 years old)..get one from our host and install it with the new battery. It makes a difference. |
your local Porsche dealer will have the correct battery
Member #750 Early911S Registry 1970 911E I know Where Jerry S. has his NYC Garage Yadda Yadda Yadda |
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I buy EVERYTHING from my Porsche dealer!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Shhhh... Uhhh
"Dyin' ain't much of a livin' boy." - Outlaw Josey Wales |
