How can i tell if i have LSD
I have a transmission from an 88 930 which i am trying to sell, and was asked if it has LSD. I have no idea do I? The case number is 930 36 2J11627. Any help is appreciated.
Conor
Old 04-09-2009, 05:45 PM
Since none of the experts have responded--turn the output shaft on one side-if the other side turns in the same direction you have LSD-if it turns in the other direction you have a normal diff-if the room turns you have taken too much
Too many cars, not enough moolah...
Old 04-09-2009, 05:59 PM
Talewinds's Avatar
Haaahahaha!
Is installing an aftermarket LSD as simple as dismantling the side bell of the transmission and slapping it in more or less? Or does the entire transmission need disassembly?
88' Carrera, Black/Black/Black, "Murdered Out" OEM.
06' BMW 'M' Roadster (Wife's car and WAY faster than mine)
Old 04-09-2009, 06:10 PM
Max Sluiter
Flieger's Avatar
Does the transaxle have an 11 or /11 stamped after the type number on the bottom of the case? The 11 stamp, added after the typ number was stamped, is often not parallel to the typ number. It signifies factory Limited Slip Differential.
Old 04-09-2009, 06:14 PM
i'm just a cook
onlycafe's Avatar
the colors, man!
Old 04-09-2009, 06:50 PM
Here's a picture you tell me i'm not sure.
Sorry the picture sucks
Old 04-09-2009, 06:57 PM
It seems to me that this is what you described as factory limited slip,yes? If so anyone have an idea of value with 50,000ish miles?
Old 04-09-2009, 06:59 PM
Bill Verburg's Avatar
915s of that era had a '12' stamped on the bottom to signify lsd.
not sure about the 930s but at a guess the '2' indicates it's probably lsd equipped.
a test would be to put it in gear and turn one side while holding the other
Bill Verburg
Old 04-10-2009, 04:45 AM
MBEngineering's Avatar
HI Conor
the bottom of the gearbox No' should be like this (the top one is G50 and the bottom is 915 and I cannot find one for a 930) it should have the "12" in the No' as Bill Verburg has explained.
there is still the check to do, as some one may have removed the LSD some where in it's life.
regards mike
Regards mike
1983 911 SC sport, 1982 mini city
Old 04-11-2009, 02:17 AM
Turns out it has LSD, turned the hub and they go the same way. thanks for all the help. Value?
Old 04-11-2009, 03:12 AM
DanielDudley's Avatar
Help me out here. that is a four speed from an 88 930 with LSD, correct ?
Old 04-11-2009, 03:42 AM
GrantG's Avatar
I'm fairly certain that LSD was standard in 88 for the Turbo (not an option)...
2022 GT3 Manual, 73 Carrera RS 2.9 Twin-Plug MFI Carbon Fiber Replica
Former: 18 GT3 Manual,16 Cayman GT4, 73 911S, Two 951S's, 996 C2, 993 C2, BMW 635CSi Euro, Ferrari 550 Maranello, 06 Evo IX w/ many mods
Old 04-11-2009, 06:28 AM
Yes 88' 4 speed with LSD from 930.
Old 04-11-2009, 02:12 PM
