Almost Banned Once
As always excellent photos and explanations by Peter Z.
- Peter |
Pete,
If I understand correctly the 2mm should be as shown below on your photo:
Matt. 83 911SC 85.5 944 NA - Sold |
I adjusted the 3/4 fork.
Here is the before picture: ![]() Here is the after: ![]() ![]() Does it look right now? I put the covers on and the shift rod selector still moves freely between the forks.
Very good! That's why I posted earlier (post #105, item #12) that the adjustment is tricky. I'm really glad that your pic was from an angle that let me see what you had done. The factory just doesn't present that clearance setting very well in the manual.
Keep the Shiny Side UP! Pete Z. |
Is paint thinner the same as laquer thinner or MEK?
Not sure, I don't know if its base is oil. I would not ever consider anything other than lacquer thinner or MEK!
Never mind, it's not the right stuff. I have to stop at the hardware store on the way home tonight.
I made a dumbass mistake.
I sealed my gasket with the Curil T per Pete's instructions. Got the intermediate case back on and put the nuts/washers on and then realized that I was missing two studs in the differential case. I forgot when I removed the old intermediate cover two of the nuts were rusted onto the studs and the nuts/studs came out of the differential case. But I could not remove them from the intermediate case because the finned castings prevented the studs/nuts from being pulled out. So I have to get two new studs/nuts. But now I'm going to have to pull my freshly sealed intermediate case off. Do I need a new gasket? Do I need to re-apply the Curil T to the old gasket? Or can I just put it back on?
Almost Banned Once
That's one of the many good things about using Curil T. You could use a little "Isopropyl alcohol" on the rag to help you get the Curil T off. Just be careful and lay the gaskets flat afterwards so they can dry... Don't use "lacquer thinner or MEK" to clean the gaskets. It will probably damage them. (BTW: You're allowed a few dumb ass mistakes when you're doing this for the first time)
- Peter Last edited by sc_rufctr; 05-14-2009 at 05:44 PM.. |
Are you sure that a new stud won't clear if it doesn't have a nut on its end?
I'm not going to take it apart until I get the studs and try that first. Do you know what part number the studs are? The PET is a little unclear.
I think I got it. M8 x 26 - 999 062 139 02
Almost Banned Once
The "26" represents the installed height of the stud not the overall length. (in Millimetres)
- Peter Last edited by sc_rufctr; 05-15-2009 at 04:14 AM.. |
I think I'm going to just buy a new gasket too. It costs $ 1.00. Which got me thinking...did I get ripped off paying $ 50.00 the gasket set since I don't think I needed half the gaskets in there???
There are certainly times when buying individual gaskets pays off big time, but buying a kit is good for a complete repair. By the time that you buy the axle flange seals, a mainshaft seal and guide tube o-ring, a shift fork seal, a diff cover o-ring, etc., you're getting up there in price. Also, when you buy a kit the parts inside are generally "fresher," which is a good thing.
Slumlord
My rule of thumb ( I'm cheap):
If you do diff side you need all the axle side seals, so the kit is a fair price. Otherwise you just need two paper gaskets (or not depending on your preference) an O-ring, a shifter seal and the input seal. In which case the 'kit' is a bit expensive. (Did I miss anything?) And on two occasions I received two identical paper seals in my 915 kit, when obviously you need two different shapes to seal the two tranny sections on a 915.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Almost Banned Once
arbita1
How is our rebuild going? Any closer???
- Peter |
It took a while to get those replacement exhaust studs. I had to remove the intermediate cover again (after I had already sealed it). Good thing I bought another gasket, because the other one ripped while I was removing the cover.
So I have all the studs on now, intermediate cover back on cleaned and sealed with a new gasket, and nuts all torqued. Basically, I'm ready to start the 5th/Reverse gear stuff. Hopefully I'll get to that this weekend and I can finish this thing. I'll take picture before I put the end cover on. Thanks for checking in.
This thing is fighting me till the bitter end. You may remember that 5th gear (fixed) was loose and I discovered that the mainshaft splines were damage, which led to a new mainshaft and first gear set. Well, I was installing the 5th gear today and noticed that there was still play (side to side) in the gear. Guess what...the gear splines are damaged as well. I didn't notice that earlier. So project on hold again until I can find a new 5th gear set. While I am doing that. Is there any way to verify that I have all my detents set up correctly?
