G50 diff case ?
Hello forum!
Simple question (I hope) !
I buy a 1989 g50 off a carrera.
The rear section (where it bolts to the engine) is damaged (cracked)
The seller give me an extra rear section from a 1990 c2 along with the diff cover.
Will these fit together ?
Is it a DIY job or a pros only job ?If so any recommended shop in NYC area ?
Old 04-18-2009, 12:50 PM
Anyone guys ???
Rgds,
Jim
Old 04-19-2009, 12:26 PM
Make Bruins Great Again
Por_sha911's Avatar
I wish I could help you. IIRC there have been discussions on previous posts about mating later model G50s to earlier cars. Check out the search button.
Joe
Old 04-19-2009, 01:08 PM
lite75's Avatar
You need to check the ring and pinion settings, unless you have the tools it's a shop only swap.
75 930, 76 930, 83 SC EFI turbo
Old 04-19-2009, 01:09 PM
KTL KTL is offline
Schleprock
KTL's Avatar
The parts will fit. But like lite75 said, you've got to check the pinion depth, differential carrier bearing preload, and ring & pinion backlash when you reassemble. Specialty tools and/or experience are key to proper assembly and operation.
Kevin L
'86 Carrera "Larry"
Old 04-19-2009, 04:47 PM
