Question on replacing hood struts
I feel stupid asking this since i thought replacing hood struts would be a simple task but i cant get the clips off the pins on the bottom end of the struts and the clips are annoying to get off period, anyone know any tricks to make them come out easier?
Old 04-29-2009, 10:10 AM
I just replaced the front lid and rear lid shocks and found it pretty straight forward. If your talking about access to the pin, say on the drivers side front thats a tough one that requires patience. I had to use a mirror and a long needle nose to get it off. Start with the passenger side and if the clip does not come off then move the pin to get the clip off. Spray some WD-40 or lubricant on it as it can get bound up. I have never heard of a clip holding a pin being stuck before! Patience and the right tool(s).
Bob
Old 04-29-2009, 10:25 AM
ths911's Avatar
check out earlier thread: Need tips on Hood Shocks
1987 Carrera Coupe
Old 04-29-2009, 10:49 AM
Never, Ever Do This
65_lincoln's Avatar
Needle nose pliers are your friend for this job. If the clip is to slide off in an upwards direction, I found that putting one jaw of the plier on the top of the pin and the other jaw on the bottom of the clip (and then squeezing) worked well.
Hope that helps, good luck.
John
1987 Carrera Targa, Lagoon Green
2012 Audi S4, Monsoon Grey
1965 Lincoln Continental convertible, Maroon--gone but not forgotten
Old 04-29-2009, 01:05 PM
burgermeister's Avatar
As it turns out, mine didn't have a clip on the driver's side. So, I didn't put one back in either. No issues at all, the pin has never moved - it is always under pressure after all. So, if you find it impossible to get the clip back on on the driver's side, just leave it off.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 04-29-2009, 01:30 PM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
When you put the clips back on you might want to attach some dental floss in case you drop one while attempting to get it on.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 04-29-2009, 03:03 PM
One of the first things I did three years ago. Couldn't have done it without these. They lock the pin in the jaw making it a much easier job. They can be purchased from Harbor Freight. I got both clips on....driver side is much harder, but it worked. Needless to say, spend the money to get a quality shock.
http://www.hobbytool.com/browseproducts/24--Hemostat-Clamp.html
1987 Carrera 3.2
Old 04-29-2009, 05:04 PM
haha thanks, its 10 pm and ive gotta wake up at 7 tommorow but im gonna run out there and take a crack at it with the coalition of ideas i got from yall, thanks everybody
Old 04-29-2009, 06:09 PM
wow so i got the drivers side strut on, i couldnt get the clip on the bottom.......you said that the hood will hold with out the clip on the bottom of the strut right?.........haha that was more frusterating then if i was armless and i tried to put a rubber on
Old 04-29-2009, 07:16 PM
Regis turd ab user
Replace with this set up and be done with it forever, when mine puke again, that's where I'm headed.
http://www.seinesystems.com/UltStrut-VehApplication.htm
Old 04-29-2009, 07:32 PM
efhughes3's Avatar
Wise advice, I put one on about 1.5 years ago, it really is a good piece.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 04-29-2009, 08:18 PM
Wow, but wait, how would mechanics make money if things were actually easy like this! hahaha thanks for showing me, next time the struts hit the bucket I'm buying some of those
Old 04-30-2009, 07:42 PM
NineOhOne's Avatar
hahahaha....
Old 04-30-2009, 08:18 PM
Well it's all done, the passenger side was wayyyyy easier as ya'll said, i just left the clip off the bottom of the drivers side strut, I'm just hoping it wont slip now. Thanks again.
Old 05-01-2009, 05:33 AM
Tags
hood , replace , struts
