motor mount washers - which way round?
Hi,
Can someone tell me which way round the motor mount, and transmission mount washers should be ? Took the engine out so long ago that I can't remember . I seem to think that I left washers on the bolts so that I could remember which way they were installed, but if this is the case, the transmission mount washers a oriented different to the engine. i.e. on engine the washers were convex side toward mount rubber, but transmission was concave side toward rubber mount.Which is correct ? Thanks in advance David |
<insert witty title here>
Convex side to the rubber is how I've always done it, based on how they were when I first dropped my engine. If you think about it, it only makes sense. If you had the concave side facing the rubber, you only be putting pressure on the outer rim of the rubber, which means there will loads of room for the bolt to travel up and down, stretching the rubber, and therefore bouncing your motor and tranny around.
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
AutoBahned
Steve W. recently answered this on Rennlist
I searched on Rennlist and couldn't find the post you're talking about, any chance you could post a link?
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
AutoBahned
here is the gist of it:
placing the washers with concave sides facing away from each other, like this: () - results in better shift quality but more vibration. placing the washers, concave sides facing inwards, like this: )(- - gives the smoothest configuration but the shifting under load is not as nice. __________________ Steve Weiner |
saw this pic:
![]() Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
That post could cause a lot of confusion - I'm glad the parentheses are there to clarify, because the terms are backwards. Concave means bent or curved inwards. Convex means curved outwards. Think of it as "caving in" to remember.
AutoBahned
he is referring to the washer itself - better reread the post...
I just re-read it - maybe my brain is tired (it *has* been a long day and I've been breathing far more gas fumes than I should be!), but I still think it's backwards. If the concave sides of the washers are facing each other, they'd look like this: ( ) whereas if the convex sides are facing each other, they'd look like this: ) (
Please correct me if I'm wrong - I hate seeing threads with discrepancies when I'm looking for a definite answer to something, so I'd hate to leave this up in the air.
Christien is reading what Steve posted correctly. The description and relationship of the parentheses are in direct contradiction.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
1con·cave
Pronunciation: \kän-ˈkāv, ˈkän-ˌ\ Function: adjective Etymology: Middle English, from Latin concavus, from com- + cavus hollow — more at cave Date: 15th century 1 : hollowed or rounded inward like the inside of a bowl convex (comparative more convex, superlative most convex) 1 : curved or bowed outward like the outside of a bowl
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
Seems to be a bit of debate about this, there seems to be mixed opinions....and no right or wrong !
How did the factory do it, anyone know ? David |
factory mount
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
OK - so to cut to the chase...which configuration gives the crispier shifts?
This = ()- or This )(-
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
After the next project
The picture above is correct. We have soft mounts in our cars. When they are installed properly it allows our mounts to move somewhat as intended by Porsche.
jwetering, () is crispier shifts, )( is normal and smoother... the way they are suppose to be mounted. If you are wanting a solid mount feel then go with Wevo, but I wouldn't recommend turning these washers around. It is not the correct way to install them. Bryan |
grateful user
washer
this was addressed in an excellence tech article a while back, factory put out a TSB telling shops they can go either way, depending on the customer drivability problems
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
All the ones I've seen were like this ( )
Seems to work fine and the other way doesn't even make sense. Just use little washers, or flat washers if you don't want the big washers to cup the rubber part, if the rubber flexes beyond a certain point. I guess you could say or hope the big washers won't go through the mount if the rubber completely dry rots and breaks out of there while they are installed ) ( |
AutoBahned
yes on the TSB - either way is ok
next step stiffer is the factory sport mounts then the Wevo - 2 stiffnesses (blue or black) |
AutoBahned
he must have been thinking about the entire configuration when he posted - I agree it is not the clearest
fwiw, factory sport mounts are origonal equipment on a 930
