gregk1's Avatar
Converting to new stile alternator Help!
I put a new stile alternator with the built in voltage regulator in my 66 911. What do I do with the wiring?? It does not charge untill I touch the fild wire to a positive wire, Then when you shut it off and restart you have to do the same thing over agen. If I hook up a hot wire the battery goes dead if I hook up a ignition switch wire the car will not shut off when you turn the key. I have tred every wire combanation I can with the wires that are there and cant get it to work. other than starting the car and going back every time and touching the wire to start the charging
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 10-16-2002, 11:28 AM
see Alternator update
Did you add the resistor across the alternator light terminals on the oil gauge? Jim
Old 10-16-2002, 12:14 PM
Early_S_Man's Avatar
Porsche Crest
Red, Blue, and brown/braided wires are only three needed. Fold back and tape off the black wire -- no longer used!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 10-16-2002, 12:15 PM
9dreizig's Avatar
Send a message via AIM to 9dreizig
Hey guys I've done this and still it's not charging ( ok I have the light on but I am putting a voltage meter on the battery and only at 12V).. Is there something I shoudl have done to the plug to the old voltage regulator ?
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 05-06-2009, 05:06 PM
