Throw it on the ground!
Rough idle diagnosed as intake leak on #2
Before replacing the gaskets on 1, 2 & 3 as recommended by the tech, does it make any sense to loosen the barrel nuts on #2 and try re-torquing them first to see if it fixes the leak?
Thanks!
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
bump
the gasket below the plastic spacer usually gets sucked in, so tightening doesn't help.
Guess you goota' know the gasket integrity,..only one way to do that,..and while you're in there,....
Best, Doyle
Recording Engineer, Administrator and Entrepeneur Designer of Fine Studios, Tube Amplifier Guru 1989 Porsche 911 Carrera Coupe 25th Anniversary Special Edition Middle Georgia |
