Rebel911's Avatar
MSD...misfire 3&5 with pattern
I just installed and MSD 6 with new Blaster 2 and MSD plug wires.
before install the car was running smooth for 30 years old. Now after install it is back firing and misfiring on number 3 and 5 at a regular pattern.
I plugged the black tach pick up directly to the wire harness from the CDI plug.
the plugs are gaped to 1.4 mm or .55 inches.
any help or ideas would be appreciated.
I did do a search and did not find what I needed.
thanks again.
Old 06-22-2009, 04:34 PM
If you are using the MSD plug ends then you are are in for some fun, just be sure you hear or feel the click as the connector mates with the plug, you can verifyvthat the wire is functioning by hooking up a digital timing light lead. Until you are sure it is not the wire it will be hard to narrow it down to anything else.
Old 06-22-2009, 04:49 PM
ps. 3&5 are right next to each other , very easy to mix em up.
1-6-2-4-3-5 ccw on an sc
Old 06-22-2009, 04:52 PM
Rebel911's Avatar
That is what I am doing right now. I am putting the timing light sensor on each plug wire.
I made a tool to help plug in the MSD plug ends. I guess I am just going to pull and check them again.
Old 06-22-2009, 04:57 PM
Rebel911's Avatar
I will check, even it they are right with the MSD coil they could be arcing.
thanks for the idea.
Old 06-22-2009, 04:59 PM
What year engine?
Old 06-22-2009, 05:01 PM
Rebel911's Avatar
sorry it is a 1979 911 ROW 3.0
Old 06-22-2009, 05:02 PM
Ok then the firing order is ccw 162435. Those wires wont arc if they are properly seated, only if they aren't connected all the way. If they are arcing you will hear them clicking, or turn out the lights and you can see. It may also be that the stock rotor is fried, if itvisnt now it will be soon, so upgrade or modify.
Old 06-22-2009, 05:11 PM
Two searches you may want to try are "msd rotor" and "msd plug wires" click advanced search and add my screen name.
Old 06-22-2009, 05:16 PM
Rebel911's Avatar
will do thanks
Old 06-22-2009, 05:18 PM
80 911 SC, Orem, Ut
RSWiser's Avatar
remember the sc distributor spins counter clockwise.
Rob
1980 911 SC
Old 06-22-2009, 08:53 PM
Good catch...I should have mentioned that before.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 06-22-2009, 08:59 PM
Rebel911's Avatar
all fixed see:link
Old 07-11-2009, 03:37 PM
Tags
msd misfire
