AutoBahned
RWebb's Avatar
big warning light module on dash
Later 911s had an expanded warning light module on the dash - mounted above and to the R of the heater control levers.
Looks like this:
Could somebody supply the dimensions of that unit?
Also does anybody know if it is a 1-piece thing or if the black plastic bezel is a separate item?
Thx!
Old 06-24-2009, 07:48 PM
muck-raker
kidrock's Avatar
1 5/8" X 7/8" OD. I do not know the inside diameter or depth, because I have yet to pull the unit from my dash (knock on wood). It appears that it is one piece, the bezel does not appear to be separate.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 06-24-2009, 08:09 PM
AutoBahned
RWebb's Avatar
thx!
if anybody has pulled the thing out, pls post on whether bezel is a separate piece...
Old 06-25-2009, 11:22 AM
It's a sickness really...
CAPierce's Avatar
I know the red lenses come out in two pieces, a top and a bottom. I do no know if the bezel can then be removed on its own, but I assume it can. I'll try to remember to check tonight. I need to replace these lamps so I've got to dig in to it a bit anyhow.
'88 Carrera Targa (Venetian Blue)
'08 Mini Cooper (Blue w/ white top)
'91 Honda CRX Si (white 100% stock)
'65 Mustang (cream - dressed as a GT350)
Old 06-25-2009, 03:06 PM
