Tlook
Guest
Posts: n/a
Trans rebuild-Where?-speedo converting?
Those in the know-Tex,
I'm about to have an aluminum 915 rebuilt, but don't know the 'Best @ economical'
place to send it to.I'm going for the LSD while their in there.
Also; is it possible to have an alum.elec.module type 915 converted to run mechanical
speedo? I have all wiring for the module type, but if I can go around it another way, I will in a heartbeat.
Thanks for your brains............RsC
Old 02-07-2001, 09:50 AM
Tlook
Guest
Posts: n/a
Never mind about the speedometer converting, I just talked to a vertex guy, and he said it's a nightmare, and expensive. I'll just run the wires...I want this aluminum transm and not the mag......however, Is 1,050.00 the cheapest it gets for rebuilds? I was quoted this from Vertex, and an extra 700.00 for limited slip.
Old 02-07-2001, 10:00 AM
Early_S_Man
Guest
Posts: n/a
Skip,
Vertex has the best price I know of, and, yes they don't like to do the electro-to-mechanical speedo switch ... about the same as your limited-slip option, I believe!
Warren Hall
1973 911S Targa
Old 02-07-2001, 10:56 AM
