atr911
Guest
Posts: n/a
Are the nuts supposed to be different?
Check this out, is there something wrong with the following pictures. Are those sprockets supposed to be different? I was looking at Andersons' book and noted they should be the same. Any ideas? Thanks (again)
Adam
atr911@hotmail.com
Old 02-07-2001, 12:42 PM
Early_S_Man
Guest
Posts: n/a
Adam,
Well, somebody used two different 'vintages' of cams in your engine! The right cam is a post-'80.5 cam and uses a 12 mm bolt to hold the sprocket, and the left one is a pre-'80.5 cam using the 46 mm nut. Does look a little odd, doesn't it?
Warren Hall
1973 911S Targa
Old 02-07-2001, 01:12 PM
