Power Window Experts Needed
How hard is it to remove the driver side power unit
Rick T |
1.367m later
On a scale of 1-10 I'd give it a 7.
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
Can the gears be replaced in the gearbox or do you need to replace the entire unit
Rick T |
1.367m later
Replace the whole unit
The power window switch will only make the window go down. If I swap the green and black wire the window will go back up. The switch is brand new also
Rick T |
1.367m later
Sounds more like the switch is wired wrong. Run a search and you'll find several diagrams with the correct plug sequence.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Sounds like the bad switch is in the drivers door.
That is if it is the passenger window
Rick 88 Cab |
The new switches are crap. Check the wiring if the you can hot wire it and make the window go up and down I would get another switch.
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
