SouthCoastPhil's Avatar
Adding LSD?
In my search for another 911, I have found some 3.2L Carreras w/G50s but w/o LSD. What's involved in adding LSD to a G50? Assuming that its feasible, which LSD do you recommend? Any ideas, and info on costs for parts and labor will be greatly appreciated.
TIA for your help,
Phil
Old 07-11-2009, 03:18 PM
Bill Verburg's Avatar
TIA for your help,
Phil
It can be done w/ the engine/trans still in the car, the side cover comes off, the diff is R&Red, pinion depth reset, button it up.
It's not going to be cheap. I'd want a GT 40/60 asymmetric lsd.
Bill Verburg
Old 07-12-2009, 07:51 AM
I've heard this one is a good one.
Old 07-12-2009, 01:54 PM
Thanks guys.
Bill: Any ballpark numbers for "not going to be cheap"?
Old 07-12-2009, 02:21 PM
Thanks guys.
Depends on shop rates, but WAG ~$3.5 - $4k
Bill Verburg
Old 07-12-2009, 03:15 PM
Navin Johnson
TimT's Avatar
but WAG ~$3.5 - $4k
Sounds right.... A Guard or Quaife diff is almost $2k Then add maybe two days labor.. You can do it while the engine tranny are in the car... it takes so little time to drop an engine, its easier to do it with the tranny on the ground...
'69 911 GT-5
'75 914 GT-3
and others
Old 07-12-2009, 04:03 PM
KTL KTL is offline
Schleprock
KTL's Avatar
If it's done in the car, only bearing preload can be set/adjusted. Pinion depth requires trans. removal and teardown!
It can be done a little cheaper if all you're after is a LSD for street use. A used factory Porsche diff from 87-98 can be put in. On the street, LSD honestly doesn't provide a whole lot of improvement- at the track it's a marked improvements/difference. You can get a used factory diff. for under $1K and have it reconditioned with new friction plates by shops with experience in doing this. All depends on what your intended use is.
Kevin L
'86 Carrera "Larry"
Old 07-13-2009, 06:59 AM
thanks all!
I am thinking LSD for DE use. (esp. coming out of turn 3 at NHMS)
Don't (yet) see a need for it on the street.
Old 07-13-2009, 07:44 PM
Why do you think you need a LSD for DE's?
I think they help more going into corners, not comming out.
Old 07-13-2009, 09:16 PM
They serve different functions going in, mid and coming out, that's why the asymmetrics are so nice
Bill Verburg
Old 07-14-2009, 06:21 AM
Originally Posted by KTL View Post
On the street, you really can't tell the difference with a late factory LSD most of the time
Fixed it for ya.
The more power you have, the more you'll appreciate a 40/65 LSD with a high (>70 ft/lb) torque setting in just about every driving situation except parking.
I put one in almost as an afterthought, partly because it enables the 915 to tolerate higher torque loads. It should have been at the top of the list - it transformed the way the car drives.
'77 S with '78 930 power and a few other things.
Old 07-16-2009, 12:20 AM
Fuchs w h o r e
This is wrong.
The pinion depth is the distance from the pinion to the differential's centerline axis of rotation. The position of the diff's axis of rotation is determined only by the trans case and side cover. Swapping out the diff does not change where the diff rotates, it rotates exactly where the original one did.
However, swapping an LSD into a gearbox that came stock with an open diff requires setting the diff bearing's preload, and the backlash between the ring gear and the pinion gear.
Old 07-19-2009, 01:10 PM
My tranny guy told me the same thing as dvkk and KTL are saying above.
He said that he won't take the measurements with the tranny in the car, because it's too difficult to get the accuracy required, he wants it on the bench.
He did say that once he's recorded the measurements he needs, he can measure the replacement diff, calculate the shims needed and that the actual swap can be done with the transmission fitted to the car just fine.
Old 07-19-2009, 02:10 PM
