No did not make it. Got back later than I thought from KY. I just got back from meeting the MTFR group down at Casey Jones Village. Had a good turnout. Hope your day ghoes successfully with all of this. I am off to change the radiator in my Suburban. Probably not as much fun as you are having...
Shane - 1984 928S |
grateful user
finally got all 12 lower studs in, ive fixed a lot of broken bolts and studs before, but nothing like this. Strange how all came out so easy but 2. Anyone thinking about replacing those 12 lower studs be prepared, this was no amature job.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Hey Don... gonna have it all back together for the last PCA Sonic Drive in this Thursday?!?!
You should come out anyway. I should finally be able to get out. Maybe Scott can drive?
Shane - 1984 928S |
grateful user
wont be going anywhere in the pcar soon, mach. shop has had my heads for almost 2 months now, but will stop by the sonic, got some things that belong to you.
Look forward to cathing up. Been awhile.
Shane - 1984 928S |
Snap-On stud remover plus impact wrench........
I don't know how I missed this thread. I could have saved you from lots of aggravation. The first time I replaced the Dilavar head studs of my SC's engine in 1999, it took me a good day (8 hours). Intense and nerve wrecking experience. However, I did an engine teardown 2 months ago and have to remove 2 broken head studs plus 10 good ones. Since I was doing a process (new to me) for removing these stubborn studs, I was skeptical about it. To my surprise, it took me just over half hour to completely remove all 12 studs without heat!!!! Actually it was about 35 minutes from first stud to the 12th lower stud. It was unbelievable!!!!! As long as there is enough stud left for the collet to grab, this is the way to go!!!!!! Our good friend Tom Butler has shown me how it was done. So I would like to share this experience with other members who would do similar task in the future. HTH. Tony |
I used a lot of heat on the case at the base of the case. MAPP gas, let it burn for about 5 minutes, used a Snap On collet tool, and a big long bar. None snapped.
Good luck to you.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Always learning
snapped extractor
I had the same problem.... To compound the situation the bolt extractor also snapped in the hole as well.
I sent it to an engineer - he used an electrode extract. Costs peanuts and gives you piece of mind. Also, not a bad idea to get the engineer to tap all the holes just to tidy them up! |
Senior Member
I consulted with John Walker before I did mine, and I had no trouble. I put oxy/acetylene heat on the cylinder spigot surface adjacent to the stud I was working on. I let it get pretty darned hot. They all unscrewed smoothly. I kept the heat on the spigot until the stud was entirely out.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
grateful user
Tony I guess im not familier with that tool. Live and learn. It was character building anyway. Ended up using a time cert on one, it was just a little to wobbly Now if only the mach. shop will hurry up.
Missed you last night Don. Not much of a showing really, mostly Boxsters. But we did have mine, another SC with 24,xxx miles (Jay), Dave's (Blue Sky) beauty of an RS interpretation, and Chuck's 993. You and Scott up for a quick trip for breakfast in Counce tomorrow. Trying to get a group to meet up with David Bailey.
Shane - 1984 928S |
grateful user
sorry i wasn't there Shane, Thur. is golf day and im usually done by 5, but because of the nice weather the course was packed and did finish till 7:30. Next time you are in town, give me a call and come on by.
