Part # needed
I am updating my front strut shock absorber, and wanted to know what is the part # for the small roll pin that hold the shock insert to the strut assembly. I can't find anything in the parts catalog neither into the Pelican catalog.
Can someone help! Thank you Stephan
1992, 964 Carrera 2, Midnight Blue 1998 BMW 318ti 2004 BMW R1100S BCR 2017 BMW R1200RS 2017 BMW 435i Mpower Pkg |
Call Bilstein, (858) 386-5900, and see if they have a dealer near you, or can possibly overnight a pin to you.
Keep the Shiny Side UP! Pete Z. |
On my 86 I just drop the shock into the strut and thread it down into place. No roll pin as in the earlier models. I wonder if you are referring to the wedge pin that locks in the ball joint to the strut?
Tony G 2000 Boxster S |
sudo apt-get purge 930
Bilsteins use a roll pin that locks the insert to the strut.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
This pic shows the roll pin right above the wedge bolt.
That's not mine I'm sad to say. It's just a pic I found while searching for a Bilstein strut.
Actually, not so nice. The ball joint/strut wedge pin/bolt is in backwards - the nut should go to the front of the car.
Yes, that's it guys, the small pin right above the shock mounting bolt/point.
I was wondering if those were easy to find at any automotive store, or only Bilstein has them. Thanks again for the replies.
I would call Bilstein.
And if you do post their part number here for future reference.
roll pin size
The pin that they use is a M7 x 45
They sell them for $2 each Ask for Clarence (800) 537 1085 Be wary of ordering them from any where else. I was able to find one that would fit but the wall thickness was much thinner than the one from Bilstien. Justin
79sc Flared with a 3.2SS conversion 9.5:1 J&E's with 964 cams and M&K exhaust Viper Green He who laughs, lasts. |
