pgeorgeson's Avatar
Revoving Momo hub
1986 Carrera. I am trying to remove my Momo steering wheel hub to get access to my steering column. I have the nut off. When I pull on the hub, it pulls about 1/8" then hangs up on something. I have tapped, wiggled, and pulled, but I can't get it off. I thought it was supposed to pull right off. Am I missing something?
1964 356 C
1970 911T
1974 914 2.0
1986 Carrera Spec911 race car #76
1990 Carrera 2
Old 08-09-2009, 03:35 PM
OldTee's Avatar
It is. Tap it down to re seat it, put a little WD40 around the splines, making sure your pressure is straight toward you, pull or pry gently. It should come.
Old Tee
all 911s sold
Old 08-09-2009, 03:51 PM
awdbandito's Avatar
It is probably in a bind. Pulling it off by hand can sometimes be a hassle. If it doesn't come off easily I usally use a gear puller.
'12 Cayman R
77 C3, 85 Carrera, 75 911S, 88 Carrera, 96 Carrera, '65 912, '06 Cayman S - Gone
Old 08-09-2009, 03:52 PM
