Replacing the valve stem seal
As mentioned in the title I'm planning to replace the valve stem seals.
Is it possible when the engine is still complete. I mean without removing the heads.
Has anyone done this before?
-Pictures
-Tools
-Attention points
All info is welcome
Old 08-11-2009, 01:30 AM
rootmatt's Avatar
Sure is possible. Using a pair of valve spring compressors available from our host, you can do valve stem seals and springs/retainers/spring-seats with the heads and cam carriers in place. Easiest if the engine is out on a stand with the exhaust and inlet manifolds removed. That way, if a valve drops in a bit, you can lift it using a finger through the exhaust/inlet port concerned. Otherwise, you can keep the valves up by using compressed air in the cylinder via the spark plug hole or just set the piston to top-dead-centre for the cylinder you are working on. Fiddly job but quite possible. Warn your friends and neighbours to expect the odd cuss.
Matt
1982 911 SC coupe RoW
moss green
SSIs and M&K 2-1 muffler
Last edited by rootmatt; 08-13-2009 at 01:08 AM.. Reason: emphasise "spring" seats, not valve seats
Old 08-11-2009, 03:02 AM
Originally Posted by rootmatt View Post
Sure is possible. Using a pair of valve spring compressors available from our host, you can do valve stem seals and springs/retainers/seats with the heads and cam carriers in place. Easiest if the engine is out on a stand with the exhaust and inlet manifolds removed. That way, if a valve drops in a bit, you can lift it using a finger through the exhaust/inlet port concerned. Otherwise, you can keep the valves up by using compressed air in the cylinder via the spark plug hole or just set the piston to top-dead-centre for the cylinder you are working on. Fiddly job but quite possible. Warn your friends and neighbours to expect the odd cuss.
Matt
WOW! I did not know this!! this is VERY COOL!
JP
'76 911s Ice Green Metallic bone stock
Old 08-11-2009, 04:35 AM
Less brakes, more gas!
euro911sc's Avatar
If you are replacing the springs and retainers I would expect that you would need to ensure the proper height on re-assy. Otherwise, just make sure all the same parts from the same valve go back on it. Best way to do that is to do only 1 at a time.
Enjoy!
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 08-11-2009, 04:53 AM
Hello Rootmatt
Thanks for the info
Concerning the compressor, do you mean this type:
Other question:
The valves seals can they just be removed by hand?
Old 08-11-2009, 05:15 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
If you don't have access to compressed air...the old time method was to feed sash cord into the cylinder and then turn the engine over gently to push the cord up against the valves (holding them closed) and then use the valve spring compressor to change the seals.
Hope this helps
Bob
Bob Hutson
Old 08-11-2009, 05:51 AM
Just out of curiosity, what kind of car do you have and what is your oil consumption?
Rick
88 Cab
Old 08-11-2009, 06:02 AM
Somatic Negative Optimist
Gunter's Avatar
Originally Posted by Porscheke View Post
Hello Rootmatt
Thanks for the info
Other question:
Not enough room for a standard compressor, you'll need these:
PEL-TOL-P7E Valve Spring Compressor, Exhaust, 911 (1965-89) [More Info]
Valve Spring Tools
[view in catalog] $59.60
PEL-TOL-P71 Valve Spring Compressor, Intake, 911 (1965-89) [More Info]
Valve Spring Tools
Remove the exhaust and HE's, move each cylinder to TDC, pressurize with compressed air into the plug hole.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 08-11-2009, 07:06 AM
I want to do this job on a 964 engine.
So the picture I added in my previous post will not do the job????
Oil consumption -> It's on the engine that stood still for many years ....
I want do do this because there was oil in the exhaust, so the valves seals don't do the job any more (see also my post off the engine with lot of pictures)
Can anyone here confirm me which compressor is perfect to do the job on intake and outlet valves for a 964 engine
Old 08-11-2009, 10:06 PM
JMHO,....
If your guides are worn, all the new seals in the world will not fix your problem.
I'd kindly recommend you measure the valve stem sideplay in the guide before doing anything.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-11-2009, 11:27 PM
Hello Steve
You are right.
But to give you some more information the engine was stalled for a long time, also previous owner filled the engine way to much (12L only from the engine)
So my guess is that oil has found his way trough the seals after these years.
still I'm also planning to check the play of the guides but still i need the right tool for disassemble the spring from the valves.
So for my question at this moment what kind of valve compressor should/ or can I use for a 964 engine
Old 08-11-2009, 11:36 PM
rootmatt's Avatar
964, eh? The compressors I used were the ones listed by Gunter (thanks). Our host's catalog suggests they are also applicable for the 964 but specifies a year range of '65-'89. I have no idea what happened after '89. Hope yours is an early one!
Re the stem seals: If they're like the earlier ones (mine is an '82 SC) then, once the springs are out of the way, they just pull off with a bit of encouragement. I may have gently gripped them with pliers .
Matt
moss green
Old 08-12-2009, 05:37 AM
Hello Rootmatt
I want to buy such a valve compressor as shown here in the thread, but if I look at the info from our host they mention indeed 65-89.
A 964 car is build between 89-94 so I'm not sure if I can use this kind of compressor???
Can anyone here confirm if it's possible with this tool?
Old 08-12-2009, 10:12 PM
Matt
Matt
Could you please explain in further depth how to do the seats with the heads and cam carriers in place? I would like to do the valve seats and the seals on my car and if I do not have to remove the heads this would be great.
Gary Kozun
83 911SC Cabriolet
Old 08-12-2009, 11:42 PM
rootmatt's Avatar
Originally Posted by mytoy View Post
Matt
Hi Gary
It appears I may have been a bit vague when I referred to seats. What I meant was the the "valve spring seat", Cat. No. 901-105-463-00-M100, that I had to replace when I broke a valve spring and it caused a mess in the nearby vicinity. I'll edit to clarify.
The valve spring seats are simple enough. With the valve covers off, install a spring compressor on a valve spring retainer. Make arrangements for the valve to remain up while you compress the spring and remove the spring keepers. Remove compressor, retainer, spring, seat and shims. Reassemble. Fiddly but not difficult.
Sorry to disappoint if you wanted to do "valve seats". I doubt that is possible.
Matt
moss green
Old 08-13-2009, 01:06 AM
rootmatt's Avatar
Hello Rootmatt
Hi
I checked the catalog and it appears that the compressors listed are OK for '89 964s but no later. No alternative is offered for later cars. I think an inquiry direct to our host may help.
I'll have to bow out here as I have never worked on a 964. I hope someone else can chime in. I believe there is a Pelican 964/993 forum that may be more helpful.
Matt
moss green
Old 08-13-2009, 01:43 AM
timeless beauty
rcaradimos's Avatar
Matt
Hey Matt,
Did you replace the worn valve seals with engine in the car or did you drop the engine? will the valve stay up enough to do the work, if that cylinder is at TDC?
LMK
Bob
87 targa
Old 08-04-2010, 03:53 PM
rootmatt's Avatar
Originally Posted by rcaradimos View Post
Hey Matt,
LMK
Hi
I had a bent valve stem as a result of a broken valve spring. I pulled the motor and put it on a stand and stripped it just enough to remove one head to change the valve. As I had one broken spring, I replaced all twelve sets and used new viton stem seals while I was in there (there's that phrase again!). Given the fiddly nature of the job, I'm glad I had the engine out. Still, others may have left the motor in?
As for your second question, the memory is a bit fuzzy. I recall the valve dropped "a bit" while I was fiddling with the springs, seals, retainers etc. What made it no problem was that it didn't drop far before resting on the piston and I could use a finger through the intake or exhaust port to push the valve up via its stem before adding the keepers. IIRC, it was necessary to have the valve all the way up (using the finger) in order for the keepers to go in properly.
Cheers
Matt
moss green
Old 08-05-2010, 05:04 AM
retrogarage's Avatar
Valve stem seals
I just did this operation on my 2.7 w/22K. Car sat for years and had all the symptoms of worn guides. Much easier if engine is removed. But yes it can be done with heads on. It will take some patience with the keepers. Make sure your new seals are round and true. I bought all new with 3 being oblong. I had to reorder a few. Do the same and order a few exrta. Compressing tools from host worked great. ABSOLUTELY NO BURNING OIL NOW. The white seals seem very hard compared to the vulcanized rubber ones.
1977 911S Targa 1967 Double Cab
(2) 1962 23 window 1958 Single Cab 1964 Ruby Red Kombi
1964 Flipseat Westy
Old 08-05-2010, 07:29 AM
timeless beauty
rcaradimos's Avatar
I think my exhaust seals on the left (cat side) are leaking,
1. I would need to remove the cat
2. remove valve cover
3. remove rocker shaft and rocker (not sure how that is done) any tips???
4. place cylinder at TDC ( will that prevent valve from dropping into cylinder head and give me enough of the stem to work with to get the keepers back on???)
5. remove keepers, retainer, springs, spring seat, worn valve seal.
6. replace seal and all parts in reverse order.
7. adjust valve(s)
Any pics and tips would be appreciated.
Thanks,
Bob
87 targa
Old 08-05-2010, 02:37 PM
