what are some oil line routing options for a front mount cooler?
1. through the front truck?
2. under the front of car, behind the bumpers? what did you guys do? anyone have some great photos to help out? hole locations would be great! TIA, cliff
poof! gone |
Track Car??? Inside the rockers
Street Car???? Outside the rockers
SWB 911S 1967 307653S in my fathers garage now LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon |
disband
bump, subscribed!
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
street legal track car, that never sees the street anymore.. SC oil line run up the car in the stock location. where the hard lines end under the front fender, is where i hope someone chimes in to assist.
poof! gone |
Vash, are you looking to put in a front valence oil cooler?
O2 In Sully We Believe |
Monkey Butt Forespin
Hey Mark, Nice to see you online!
We now return you to your regularly scheduled Thread.
Fred Hurder Jr For Tech Questions: '84 911 Carrera Cabriolet (US) Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler 22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Please be more specific as to the type of oil cooler.
Factory right front fender? Front valence? Thanks, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Tony G 2000 Boxster S |
sorry, front valence cooler.
helping a friend. he is too shy to chime in..hahah.
poof! gone |
If I have time this afternoon I'll remove the front wheels on the Carrera and snap a couple of pics for you.
Some route thru the trunk some route around the outside of the tub, depends on where the I/O ports on the cooler are
I'd mock up the cooler where it will physically sit, then check for where to run the lines, and for air egress
Here's a few pics from my stash that helped me. I have a fender mount cooler as well as a front mounted cooler. The first pic of the red car is mine, the second pic shows how to plumb the 2 coolers in series and the third is another from my stash. Hope it helps.
Tom ![]() ![]()
'74 911 Red Sunroof Coupe, 3.6L, etc... '76 912 Yellow SPEC 911/911CUP |
We usually run the lines under the right rocker (OEM or Aeroquip) for street cars but in some cases on race cars, the lines run inside the car on the floor, either next to the tunnel or right sill for protection.
Make sure your front oil cooler installation permits sufficient air to exit the cooler otherwise it won't be very effective,...
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
As with most mods, YMMV. Sherwood |
disband
any pics of hose through the trunk area & where the hols had to be drilled?
This one happens to be a street legal C3.0RS ![]()
Running the lines through the passenger compartment is usual only on a pure track car
here's a nicely done setup ![]()
