vash's Avatar
what are some oil line routing options for a front mount cooler?
1. through the front truck?
2. under the front of car, behind the bumpers?
what did you guys do?
anyone have some great photos to help out? hole locations would be great!
TIA, cliff
poof! gone
Old 08-20-2009, 10:40 AM
dhrcr911s's Avatar
Track Car??? Inside the rockers
Street Car???? Outside the rockers
SWB 911S 1967 307653S in my fathers garage now
LWB 911T 1971 9111120264 Back in my garage after a lenghty stay in Oregon
Old 08-20-2009, 10:47 AM
disband
juanbenae's Avatar
bump, subscribed!
Old 08-20-2009, 04:21 PM
vash's Avatar
street legal track car, that never sees the street anymore.. SC oil line run up the car in the stock location. where the hard lines end under the front fender, is where i hope someone chimes in to assist.
poof! gone
Old 08-20-2009, 04:45 PM
Vash, are you looking to put in a front valence oil cooler?
O2 In Sully We Believe
Old 08-20-2009, 06:25 PM
Monkey Butt Forespin
84_Carrera's Avatar
Hey Mark, Nice to see you online!
We now return you to your regularly scheduled Thread.
Fred Hurder Jr
For Tech Questions:
'84 911 Carrera Cabriolet (US)
Weltmeister Chip, Fabspeed Euro Pre-Muffler, M&K 1-in / 1-out Muffler
22 ERP /29 Sander Hollow T-Bars, Bilstein HD Struts / Sport Shocks
ERP Poly-Bronze Bearings (A-Arms & Spring Plates), Stock Swaybars
Turbo Tie Rods, '92 C2 5-Spoke wheels w/ 1" adapters, Drilled Zimmermans
Yes, I drive mine as much as possible. If it's >32° & sunny, I've got the top down.
Old 08-20-2009, 06:36 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Please be more specific as to the type of oil cooler.
Factory right front fender?
Front valence?
Thanks,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 08-20-2009, 06:41 PM
Kremer ST Re-creation
check the plumbing for this double wheel well set up.
Tony G
2000 Boxster S
Old 08-20-2009, 07:02 PM
vash's Avatar
sorry, front valence cooler.
helping a friend. he is too shy to chime in..hahah.
poof! gone
Old 08-20-2009, 08:11 PM
If I have time this afternoon I'll remove the front wheels on the Carrera and snap a couple of pics for you.
Old 08-21-2009, 04:49 AM
Bill Verburg's Avatar
Some route thru the trunk some route around the outside of the tub, depends on where the I/O ports on the cooler are
I'd mock up the cooler where it will physically sit, then check for where to run the lines, and for air egress
Bill Verburg
Old 08-21-2009, 05:46 AM
Tom '74 911's Avatar
Here's a few pics from my stash that helped me. I have a fender mount cooler as well as a front mounted cooler. The first pic of the red car is mine, the second pic shows how to plumb the 2 coolers in series and the third is another from my stash. Hope it helps.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 08-21-2009, 08:02 AM
We usually run the lines under the right rocker (OEM or Aeroquip) for street cars but in some cases on race cars, the lines run inside the car on the floor, either next to the tunnel or right sill for protection.
Make sure your front oil cooler installation permits sufficient air to exit the cooler otherwise it won't be very effective,...
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-21-2009, 10:32 AM
Steve is typically right on. However, on some front bumper installs, the backspacing for the cooler will be very tight. It'll depend on the cooling requirements of your particular engine, but on mine (2.7 RS type w/E-cams), the front cooler (Earl's) sits flush with the front bulkhead. Highway and stop and go temps are typically 180-190ºF and never exceed 210ºF.
As with most mods, YMMV.
Sherwood
Old 08-21-2009, 11:15 AM
disband
juanbenae's Avatar
any pics of hose through the trunk area & where the hols had to be drilled?
Old 08-22-2009, 12:01 AM
Sherwood
Mine will go to about 200-205F then the front thermostat opens and it drops back to 185-190F and pretty much stays there.
Old 08-22-2009, 03:53 AM
here are some pics of typical factory RS/RSR setups from the early '70s
This one happens to be a street legal C3.0RS
Bill Verburg
Old 08-22-2009, 04:20 AM
Running the lines through the passenger compartment is usual only on a pure track car
here's a nicely done setup
Bill Verburg
Old 08-22-2009, 04:26 AM
