A/C Condenser Blower Testing?
When I bought my 87 911, I was told that the air conditioner was not working (surprise!). I have found that the A/C condenser fan in the front trunk was disconnected. I imagine that either the motor or bearings are shot.
Can this be tested simply by putting 12v to one terminal and ground to the other? I assume that polarity is not important for testing as it should spin in either direction. Correct? Finally, I saw a mention of upgrading to a footwell blower fan, as it is of similar size but turns more RPM. Is this the case? Thank you. |
You can test the fan that way. The brown wire is the ground or negative. Finding the replacement motor is the difficult and expensive part.
Your A/C will still work without the fan, but not as designed. If the A/C is just not working the front blower fan is jut one of you problems.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Detached Member
Someone gave me a used A/C blower and I decided to bench test it with a battery charger. After ten minutes, it caught fire.
Hugh |
That's pretty much what I was hoping to avoid.
1987 911 Coupe, Diamond Blue Metallic 2006 Cayman S, Seal Gray 1983 911 Targa, Black: The Dirty 911 (GRM) |
It's pretty easy to pull if you want to bench test it instead of in the car. 4 or 6 phillips screws in the trunk.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
The AC condenser fan is a common cause of fires in the 911. If the motor starts to squeal, best to disconnect and replace or service it pronto!
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
porsher
I have one for sale, it has never caught fire.
Throw it on the ground!
Finding a replacement motor is not difficult or expensive. Repl cost is $59 and the change out is a snap. You do want to add an in line fuse to protect the circuit from overheating/fire failure as these motors are prone to if the A/C is not functioning properly and the circuit is energized continuously
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Not to hijack the thread but on a related note...( think I asked this before and did not get an answer) but is there a confirmed source for the evaporator fan? I seem to recall that both motors are physically similar. I know the "hurricane" replacement is not designed for the Carrera's from '87-'89.
TIA
Buck '88 Coupe, '87 Cab, '88 535i sold, '19 GLC 300 DD Warren Hall, gone but not forgotten |
Thank you for the info. I've seen the replacement motor from Pelican: http://www.pelicanparts.com/cgi-bin/smart/more_info.cgi?pn=0-130-063-043&catalog_description=Motor%20for%20Front%20A%2FC%20 Condenser%20Blower%20Assembly%20911-624-906-00%2C%20911%20(1986-89)%2C%20911%20Turbo%20(1986-89)%2C%20Each Is it difficult to remove the original fan (blades) from the motor shaft?
1987 911 Coupe, Diamond Blue Metallic 2006 Cayman S, Seal Gray 1983 911 Targa, Black: The Dirty 911 (GRM) Last edited by Woodyhfd; 08-21-2009 at 06:08 PM.. Reason: Clarity |
Be careful removing the fan. It is delicate and will separate from the collar if too much force is applied. If you bend the fan it will be out of balance. Yes, there is an allen screw (or two?)
Scott Wilburn 1988 911 Carrera 3.4 L 1998 M3 1984 308 QV |
