Which relay controls the fog lights?
Does anyone have a picture, or wiring diagram?
I know the obvious, I can find one on the site, I looked and can't find it.
I can trace the wiring, I did and can't figure this out thats why I'm posting.
I can buy a Bentley's manual, yes I can but I don't have a spare $100 to spend.
I appreciate all of the comments I received in the last post but save your keystrokes. If you have a pic or wiring diagram for the fog lights, fuse location or relay, please share.
Thank you.
Old 09-17-2009, 05:44 AM
geoz's Avatar
Not sure there is one. I think it is just the switch, but I'm happy to be proven wrong.
Old 09-17-2009, 05:56 AM
68Sporto
MrJTP's Avatar
The schematic in my 68 workshop manual shows the fog lights using only the dash switch. A relay would be a good idea though.
Tony
Porsche owner since 1967
1998 Boxster
1968 911 Sportomatic project
Old 09-17-2009, 06:57 AM
crustychief's Avatar
the second one from the front. Just replaced mine.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 09-17-2009, 07:14 AM
Somatic Negative Optimist
Gunter's Avatar
When asking questions, the year/type really helps.
If you don't buy the Bentley, there is always the electrical schematic in the Tech Section on PP.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 09-17-2009, 11:42 AM
No help
My signature says it all but just in case you are not looking, it a 1979 Porsche 911 SC.
The 2nd relay from the front is clicking when I remove it with the lights and fog light switch turned on but the fogs don't turn on.
I traced the fogs back into the car through the facia and found a clear/cloudy plastic connector. No power to it, disconnected it and ran a hot and ground to the wires the fogs turn on no problem.
No fuses are burn out and the 2nd relay from the front is clicking.
Any ideas what I should check next?
Old 09-17-2009, 08:45 PM
Formerly known as Syzygy
Canada Kev's Avatar
Try using a known good relay in that position. Just because it is clicking doesn't mean that it is working properly.
Kevin
Old 09-17-2009, 08:56 PM
Canada Kev's Avatar
And for the record, my fog relay is the second from the front, as well, though I own a Carrera not an SC. HTH
Kevin
Old 09-17-2009, 09:05 PM
Gunter's Avatar
Sounds good, keep trying.
Old 09-18-2009, 07:48 AM
