Quick Learner
levdeb's Avatar
Zenith carb is missing float pin!!
So, rebuilding my carbs, and as I remove the top of the carb, I notice the floats are just hanging to the side. One of the little pins is missing. Not in the bowl, not anywhere. I assume someone rebuilt it last time, and forgot to put it in?!?
Anyway, looking for ONE float pin! Anyone? Or can I just make one? No, forget I said that...
I know, its crazy... any help would be appreciated!
Thanks so much!
Old 09-17-2009, 04:41 PM
austin552's Avatar
Why not just replace the float? Is it the front or back float?
1974 911s
Old 09-17-2009, 05:17 PM
Quick Learner
levdeb's Avatar
The floats are fine, just the pin is missing. They floats look identical, front to back. I have had them off and partially apart for some time, so not sure whats front or back right now. lol
All the pins look identical.
Thanks!
Old 09-17-2009, 05:33 PM
The people who invented Porsches in the late 1940s, mere months after a disaster like ten thousand 9/11s, were able to make camshafts by hand, with a steel billet and a few files.
Make a pin, forgodsakes.
Stephan Wilkinson
'83 911SC Gold-Plated Porsche
'04 replacement Boxster
Old 09-17-2009, 05:56 PM
Quick Learner
levdeb's Avatar
I finally get Steve to respond to a post of mine, and ur telling me to make a Porsche part?!?
yeah, I was going to just make one, and assumed the collective forum would say "do it right and buy the pin". Guess I was wrong. It's not like it's gold plated or anything...
Thanks! Bill
Old 09-17-2009, 06:22 PM
Bill,
I have a few Zeniths that are in parts.
Pm your address to me and Ill mail it out to you.
Old 09-17-2009, 06:46 PM
Quick Learner
levdeb's Avatar
PM'ing now! Thanks Joey!
Old 09-17-2009, 06:48 PM
Okay, buy the part, Quick Learner, I don't care. I thought your problem was that there was no such part available.
Stephan Wilkinson
Old 09-17-2009, 06:57 PM
Quick Learner
levdeb's Avatar
I had no idea either. Just wan to make sure I am doing it right. That's why I read all those books!
I remember once while in the Air Force, we lost 2 F-16s and nobody knew why they crashed. We waited for the order on how to fix the fleet before any jets could fly again. Finally the tech order came in, and we were to "unplug cannon plug from ecu, wrap plug in ziplock baggie, and tie baggie closed with zip tie". Every $20 mil jet was being "fixed" that way. Couldn't believe it.
To make a long story boring, when the thought of "making a pin" popped in my head, that F-16 memory came rushing back. Lol
I just want to make sure my first 911 sudo-resto is a good as I can handle. Quick learning and all.
Thanks Steve. Nothing but respect for ya.
Bill
Old 09-17-2009, 07:27 PM
Senior Advisor
James Brown's Avatar
I did mine (removed pins) to clean the corrosion, they look like stainless steel wire. Just get the dimensions and replicate it. Make sure that the float moves freely and your ok.
08 Cayenne Turbo
Old 09-17-2009, 08:51 PM
docrodg's Avatar
Use the shaft of a drill bit the right size.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 09-18-2009, 12:24 AM
Senior Advisor
that's a great idea! now is it metric, fraction, number, letter, or Japanese?? or british standard (gasp)
08 Cayenne Turbo
Old 09-18-2009, 07:55 AM
It's the one that fits through the holes.
Stephan Wilkinson
Old 09-18-2009, 08:00 AM
austin552's Avatar
I was going to send you the float free but thats okay.
KYO
1974 911s
Old 09-18-2009, 03:07 PM
dshepp806's Avatar
Nope,..he was asking for help (sources, included)
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 09-20-2009, 04:41 PM
Well, my source, as I said, was to make one. Somebody offered the excellent suggestion that there was a huge variety of hardened-steel (and cobalt) drill bits, one of which will fit. Somebody else said a short length of stainless-steel wire might work. Ingenuity is your friend, not weberfloatpins.com.
Stephan Wilkinson
Old 09-20-2009, 05:00 PM
If it's like a Weber float pin, it has a section that threads into the upper carb casting. The Weber float pin must be safety wired in place, otherwise it can back out. When that happens, the now-independent float goes out of alignment with the float needle valve which allows unmetered and raw fuel into the float bowl which overflows into the throttle bore and into the cylinder. Worst case; the cylinder hydrolocks and breaks the piston. Best case; the engine won't crank over due to the hydrolocked cylinder.
Sherwood
Old 09-20-2009, 06:35 PM
Quick Learner
levdeb's Avatar
Thankfully Joey is sending me a pin for my Zenith. I would prefer to keep the drill bits for drilling holes, not filling them.
Thanks all!
Old 09-20-2009, 06:40 PM
