msd on 3.2?
Hi to all, i have used msd 6al and digi 6 on my early cars and find them really good especially on the carbed engines.
I would like to know if an msd digi 6 or 6al can be installed in a 3.2 with dme? thanks in advance rommy
Old 10-05-2009, 06:08 AM
What's the point? The DME ignition is already robust enough to fire my plugs gapped at 0.060" on my 86 as long as you get rid of the stock Beru cables.
Regardless how you go, you will still need replace your copper Beru cables for carbon core or equivalent to handle the higher voltages required to fire a bigger gap. In addition, I would recommend upgrading your cap and rotor to HEI rated components.
Cheers,
Joe
Old 10-05-2009, 07:14 AM
NOS911
mxessin2's Avatar
Send a message via Yahoo to mxessin2
I would like to know if someone has done this as well.... I would like to use it to retard my timing back 4 to 6 degrees.....
My Pelican Page
Old 10-05-2009, 12:03 PM
I have installed a MSD 6AL on mt 1985 3.2 targa, but without changes in ignition timing. Subjectively response and performance seem much better throught the rev range. MSD reccomend increasing the plug gap but in my case that was associated with misfire; much better with the factory gap
Regards
Old 10-06-2009, 02:34 AM
Regards
So what is the point in installing a high energy, high voltage ignition system if you are unable to open the plug gap in order to take advantage of the higher energy available with a bigger plug gap? The factory gap only requires the lower voltage that your stock system already supplies.
In my situation, I was able to take full advantage of the energy available with the stock DME ignition by upgrading my ignition cables, cap and rotor to make the 0.060 plug gap work.
Cheers,
Joe
Old 10-06-2009, 06:14 AM
spence88mph's Avatar
You can install an msd with great results, many report an improvement in many areas:
here's one thread:
MSD6AL on a Protomotive 3.2 Turbo
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 10-06-2009, 06:20 AM
NOS911
mxessin2's Avatar
The advantage for adding a MSD 6200 in my application is so I can add the optional retard timing control module. P/N 8680. Then I can retard the timing for my Nitrous set up. The stock DME can only retard the timing by -2.79 degrees with the fuel quality switch. By adding the MSD system I could adjust the timing back to 15 Degrees.
What cables, cap and rotor did you use Joe?
Thanks, Mike
My Pelican Page
Old 10-06-2009, 12:43 PM
gtc gtc is offline
abides.
gtc's Avatar
+1... Also interested in hearing of any possible alternatives to the $50 factory cap. It's not a huge deal to me, but I never understood what made our caps 4x more expensive than the SC caps.
Graham
1984 Carrera Targa
Old 10-06-2009, 02:34 PM
abit off center
cgarr's Avatar
Can you use the MSD on a twinplugged 3.4 using an andial splitter? if so would you need 2 units? and would it help when runniing 10.5/1?
______________________
Craig
G2Performance
Old 10-07-2009, 06:44 AM
You could probably trigger it with the tach output (with science project adapter circuit) but unless you want to get into the software in the DME you would have no way to adjust timing to account for the delays in the MSD.
Rick
88 Cab
Old 10-07-2009, 08:46 AM
NOS911
mxessin2's Avatar
To what I understand the DME triggers the MSD without the tach adapter on the 3.2.
My Pelican Page
Old 10-09-2009, 11:47 AM
So you just hook the wire at the coil that goes to the DME to the MSD white wire? Does that work?
Rick
88 Cab
Old 10-09-2009, 01:05 PM
NOS911
mxessin2's Avatar
The MSD white white wire connects to the old coil negative (orig small green wire)
Someone has done it here - MSD6AL on Carrera 3.2 engine ???
My Pelican Page
Old 10-09-2009, 08:33 PM
