Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Always use the right tool (torque heads)
OK, so I've searched this forum and the rebuilding forum, looked in the bentlley, etc, and cannot (quite) get the answer to this.
Next valve adjust I'm going to torque the heads, since my rebuild has 5000 miles or so on it. Running fine, no oil leaks or strange sounds.
I cut a 10mm allen key to do this job - my question is - how long should I cut it, so that I can get the torque wrench in on those pesky ones in the back ? I'd rather get it cut in advance since it's a PITA. Can somebody measure their Porsche 10mm allen tool and let me know ? Right now I've got mine at 6" / 155 mm, see pic.
thanks muchly
Mark Petry
Bainbridge Isand, WA
Old 10-08-2009, 01:03 PM
dtw dtw is offline
GAFB
Huh? Just go to Sears and get a set of metric 3/8" Allen sockets. That and a 3/8" extension and you're all set.
Several BMWs
Old 10-08-2009, 01:07 PM
Senior Advisor
James Brown's Avatar
yes the allen head should be 10 MM and you add a 3/8 extention to the torque wrench. the reason is the long allen sockets are "softer" then extentions so the torque value is more accurate.
NAAAAAA just kidding, your overthinking this! 6" inch allen socket is fine or do what DTW did, a lot easer.
08 Cayenne Turbo
Old 10-08-2009, 01:34 PM
dtw dtw is offline
GAFB
Ohhh now I see the pic...that thing should probably be fine...
Several BMWs
Old 10-08-2009, 01:37 PM
Quantum Mechanic
mpetry's Avatar
thanks guys
on the 356 cars the socket would not get in there, you needed the "long allen".
much appreciated.
Mark Petry
Bainbridge Island, WA
Old 10-08-2009, 01:54 PM
AutoBahned
RWebb's Avatar
by softer, he means less stiff - the Allen bit can twist, making the torque inaccurate
I've never measured this but a mech. told me that & it makes sense.
Old 10-08-2009, 03:31 PM
Wavey's Avatar
like a torsion bar
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 10-08-2009, 04:10 PM
"by softer, he means less stiff - the Allen bit can twist, making the torque inaccurate
I've never measured this but a mech. told me that & it makes sense."
Wrong, the torque will be the same at both ends of the bit no matter how long it is. The mechanic is confusing torsional deflection ("windup") with torque - they are not the same.
Old 10-08-2009, 04:44 PM
AutoBahned
RWebb's Avatar
thx Jim. Now that you explain it, that makes sense. There would not be a difference until velocity or accel. changed.
Old 10-08-2009, 04:57 PM
Quantum Mechanic
mpetry's Avatar
wind up
at 25 foot pounds, I doubt it would wind up very much.
any idea if I'm in the ballpark on length ? Pretty cramped in that engine compartment.
Mark Petry
Old 10-08-2009, 05:03 PM
j_mancini's Avatar
Agreed. 25 ft-lb is not a lot of torque, hard to imagine it making any difference. If you were twisting 180 ft-lbs-- that's different.
John
1982 911SC Targa ~ Gulf Blue (gone but not forgotten)
Old 10-09-2009, 09:36 PM
AutoBahned
RWebb's Avatar
seems no one knows the length - I sure don't remember
try: PET (tools section); Wayne's book; Bruce Anderson's book - IIRC, there is a table with all the tools you need on one page
Old 10-09-2009, 10:17 PM
prschmn's Avatar
Twist in the driver isnt going to make any difference-the torque is still the same. Now if you were torquing by angle-that would be messy
Mark
www.exotechpower.com
1981 Targa-messed with. 91 C2 supercharged track rat
Radical Prosport-irritates the GT3 guys
40 years of rebuilding services
Old 10-10-2009, 05:48 AM
MBEngineering's Avatar
HI Mark Petry
the Porsche tool for you 8in total length and 1/2 in drive,
regards Mike Bainbridge
Regards mike
1983 911 SC sport, 1982 mini city
Old 10-10-2009, 06:00 AM
Quantum Mechanic
mpetry's Avatar
Thanks Mike
that is BEAUTIFUL!
On ebay now ? I'll check.
thanks man
Mark Petry
Old 10-10-2009, 10:37 AM
Senior Advisor
HOW TO COMPUTE TORQUE WHEN USlNG ADAPTORS
If an adaptor or extension is attached to the square drive of a click-type torque wrench and this adds to its length, then the applied torque will be greater than the pre-set torque. A formula can be used to find what the preset-set torque should be in order to obtain the correct applied torque.
Here is the formula:
preset torque = torque wrench pullpoint X torque desired
.....................torque wrench pullpoint X extention lengh
this becomes RS= A X T
.........................A + B........WHEN
RS= A X T OR 12 X 30 OR 360 OR 20 FT/LB
....................12 X 6.......18
RS = Torque setting of the torque wrench.
A = Distance from the center of the square drive of the torque wrench to the center of the handle grip pull point.
B = Length of the adaptor from the center of the square drive to the center of the nut or bolt. Use only the length which is parallel to the handle. See figure 1
T = Torque desired. This is the actual torque applied to the fastener. Here is a typical problem: What should the setting be when ‘‘A’’ is 12’’, ‘‘B’’ is 6’’ and ‘‘T’’ is 30 Ib. ft.
Therefore 30 pound foot of Torque will be applied at the fastener when ‘‘RS’’ is 20 pound foot.
Note: If the torque wrench reads in pound foot, then ‘‘T’’ should also be in pound foot. ‘‘T’’ and ‘‘RS’’ should be in the same unit of measurement. ‘‘A’’ and ‘‘B’’ should also be the same unit of measurement.
Hope this helps or just muddles the waters. if the torque is 25 ft/lbs, I don't think this matters much.
08 Cayenne Turbo
Old 10-10-2009, 02:14 PM
Senior Advisor
just some more torque fun, doesen't really apply in this case, just for extentions FWIW
08 Cayenne Turbo
Old 10-10-2009, 02:17 PM
prschmn's Avatar
It should be understood that this does NOT really apply to "extentions" but things along the line of a crowsfoot such as you'd use for old style cam nuts. Only an attachment that increases the overall length of the torque wrench has this effect.
Mark
Old 10-10-2009, 03:25 PM
Senior Advisor
like a "extention"
08 Cayenne Turbo
Old 10-10-2009, 07:10 PM
Senior Advisor
like this one, B in the diagram
08 Cayenne Turbo
Old 10-10-2009, 07:14 PM
