Throw it on the ground!
Things not to skimp on - replace the flywheel!
Did the clutch job along with an engine swap in June and opted to have the flywheel re-surfaced vs. replace to save $$$. I did not have it balanced so it could be warped and out of balance - I just don't know. I thought about this long and hard an opted not to replace - big mistake!
Anyway, I get chatter/vibration not so much out of 1st gear but really out of 2nd gear that is SUPER ANNOYING. My commute has recently changed and I find myself sitting in interstate traffic jams and the clutch chatter is driving me nuts. So much so that I'm willing to redrop the engine to replace the flyhweel. I also wish I had taken the time to replace the intake gaskets when I had the engine on the stand for 9 mos. I'll be replacing them this weekend to fix an intake leak. Before ![]() After: (done by The Clutchman - local mobile servicer for$60)
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. |
Almost Banned Once
Was the fly wheels taken of the engine to re surface it or was it done in place?
Did the surface have micro cracks in it before resurfacing? The surface looks good in the second photo. Fly wheels are cut differently to brakes and looking at the second photo it looks like it's been cut correctly. I have "fly cut" my own flywheels and done it for people I know on my mill using a rotary table. I built a special jig for securing the fly wheel to the rotary table and use a roller on a small jack bolted to the table to support the outer edge... So far I have done about 10 fly wheels but most of those were just a skim to remove the glazing. If you need to cut heaps off a fly wheel to get it flat then often it will be out of balance and spec when you're finished.
- Peter |
New Flywheel
You had a new flywheel installed for $60? Not including the cost of the flywheel, right?
<insert witty title here>
It could very possibly just be a clutch adjustment issue. I also only had mine resurfaced when I rebuilt my tranny and put in a new clutch. I had about 50/50 advice, but the look from my wife when she saw the Pelican invoice for the clutch and tranny bits told me resurfacing was the better option
![]() When I first put it back in I had horrible chatter, exactly like you described - pretty much only going into 2nd from 1st. I adjusted the clutch and it's much better now. I still get it sometimes, so I need to adjust again, but it made a big improvement. I'd strongly suggest adjusting your clutch before dropping your engine again!
Current: 1987 911 cabrio Past: 1972 911t 3.0, 1986 911, 1983 944, 1999 Boxster |
According to your signature, your car is a 87, so a G50.
I always thought that you couldn't re-surface a G50 flywheel. |
Not sure how your first flywheel was "turned". The preferred method of resurfacing frictional surfaces such as rotors, brake drums and flywheels is to use a grinding stone rather than a typical carbide cutting tool. A cutting tool will skip over heat-hardened areas of the surface leaving an uneven surface. A grinding wheel will remove these hard spots and produce an even flat surface.
As an aside, the cutting pattern produced by a lathe bit is a circular spiral, much like the grooves in a vinyl record. This produces a thread-like effect which forces one contact area to shift (like a phonograph needle). While of little significance in a flywheel/clutch disk, this can produce noise when a brake pad or brake shoe tries to move along the sprial "groove". Shops who use this type of cutting head should finish up by using a sanding disk to break up the spiral pattern. Still, not as good. MHO, Sherwood |
Clutch Chatter
I would check all my clutch adjustments first...I had the same issue and adjusted the cluth, no more problems!
I had the flywheel resurfaced off the car from a mobile resurfacer (equip on his truck) for a total cost of $60
G50 gearbox - no cable to adjust
Correct - it is recommeded that they be replaced, not resurfaced. I got enough recommendations here from others who have had success and took the risk. Now I wish I hadn't.
Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. Last edited by mthomas58; 10-09-2009 at 11:14 AM.. |
3.4 Bigger is better
Mark not sure what caused your problem. I have heard of the flywheels being warped and need to be checked before machining. Possiblity?
I had my G50 flywheel resurfaced as I was going to use a spring centered clutch. $30 at what is considered the best shop in town. Would not have it resurfaced if I was using the rubber centered clutch. Another thing my shop did that I didn't see on your flywheel is they took the same amount off the outside lip as they did on the main surface area. Take a look at the flywheel and you can see the two surfaces that they machined. Also the curved pattern of the machining is visible. ![]() The spring centered clutch has been great and no noticeable difference from the rubber centered clutch.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Related problem. Replaced my Clutch (Sachs) and flywheel (Sebro) on my 88 911, and now have a vibration/chatter at low RPM's (2000 - 2500) under load/acceleration progressively worse in higher gears. Also replaced axles (Leobro's) No problems of this type before engine drop. Ideas or links to other posts welcome.
Vibration under load sounds like a CV joint issue. Yes you said you replaced them, could be one of the new joints is too tight and binding.
Driver
In my DD Honda, I had the dealer replace the clutch when they were rebuilding the motor due to a warranty issue. The flywheel was resurfaced. Afterwards, the clutch chattered horribly. The problem "wore out" after about 10 months. That was about 3 years ago, and no further problems. So maybe just give it a few more months?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Sherwood |
make sure you have the 15mm nuts tight on the trans. if look it will vibrate...
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
isn't chatter on a resurfaced flywheel pretty common? it's like getting a lightweight flywheel that makes the same noises
Check your engine mounts.
