Quantum Mechanic
Always use the right tool (torque heads)
OK, so I've searched this forum and the rebuilding forum, looked in the bentlley, etc, and cannot (quite) get the answer to this.
Next valve adjust I'm going to torque the heads, since my rebuild has 5000 miles or so on it. Running fine, no oil leaks or strange sounds. I cut a 10mm allen key to do this job - my question is - how long should I cut it, so that I can get the torque wrench in on those pesky ones in the back ? I'd rather get it cut in advance since it's a PITA. Can somebody measure their Porsche 10mm allen tool and let me know ? Right now I've got mine at 6" / 155 mm, see pic. ![]() thanks muchly Mark Petry Bainbridge Isand, WA Last edited by mpetry; 10-08-2009 at 01:07 PM.. |
GAFB
Huh? Just go to Sears and get a set of metric 3/8" Allen sockets. That and a 3/8" extension and you're all set.
Several BMWs |
Senior Advisor
yes the allen head should be 10 MM and you add a 3/8 extention to the torque wrench. the reason is the long allen sockets are "softer" then extentions so the torque value is more accurate.
NAAAAAA just kidding, your overthinking this! 6" inch allen socket is fine or do what DTW did, a lot easer.
08 Cayenne Turbo |
GAFB
Ohhh now I see the pic...that thing should probably be fine...
Several BMWs |
Quantum Mechanic
thanks guys
on the 356 cars the socket would not get in there, you needed the "long allen".
much appreciated. Mark Petry Bainbridge Island, WA |
AutoBahned
by softer, he means less stiff - the Allen bit can twist, making the torque inaccurate
I've never measured this but a mech. told me that & it makes sense. |
like a torsion bar
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
"by softer, he means less stiff - the Allen bit can twist, making the torque inaccurate
I've never measured this but a mech. told me that & it makes sense." Wrong, the torque will be the same at both ends of the bit no matter how long it is. The mechanic is confusing torsional deflection ("windup") with torque - they are not the same. |
AutoBahned
thx Jim. Now that you explain it, that makes sense. There would not be a difference until velocity or accel. changed.
Quantum Mechanic
wind up
at 25 foot pounds, I doubt it would wind up very much.
any idea if I'm in the ballpark on length ? Pretty cramped in that engine compartment. Mark Petry Bainbridge Island, WA |
Agreed. 25 ft-lb is not a lot of torque, hard to imagine it making any difference. If you were twisting 180 ft-lbs-- that's different.
John 1982 911SC Targa ~ Gulf Blue (gone but not forgotten) |
AutoBahned
seems no one knows the length - I sure don't remember
try: PET (tools section); Wayne's book; Bruce Anderson's book - IIRC, there is a table with all the tools you need on one page |
Twist in the driver isnt going to make any difference-the torque is still the same. Now if you were torquing by angle-that would be messy
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
HI Mark Petry
Bainbridge Isand, WA the Porsche tool for you 8in total length and 1/2 in drive, ![]() ![]() regards Mike Bainbridge
Regards mike 1983 911 SC sport, 1982 mini city |
Quantum Mechanic
Thanks Mike
that is BEAUTIFUL!
On ebay now ? I'll check. thanks man Mark Petry Bainbridge Island, WA |
Senior Advisor
HOW TO COMPUTE TORQUE WHEN USlNG ADAPTORS
If an adaptor or extension is attached to the square drive of a click-type torque wrench and this adds to its length, then the applied torque will be greater than the pre-set torque. A formula can be used to find what the preset-set torque should be in order to obtain the correct applied torque. Here is the formula: preset torque = torque wrench pullpoint X torque desired .....................torque wrench pullpoint X extention lengh this becomes RS= A X T .........................A + B........WHEN RS= A X T OR 12 X 30 OR 360 OR 20 FT/LB ....................12 X 6.......18 RS = Torque setting of the torque wrench. A = Distance from the center of the square drive of the torque wrench to the center of the handle grip pull point. B = Length of the adaptor from the center of the square drive to the center of the nut or bolt. Use only the length which is parallel to the handle. See figure 1 T = Torque desired. This is the actual torque applied to the fastener. Here is a typical problem: What should the setting be when ‘‘A’’ is 12’’, ‘‘B’’ is 6’’ and ‘‘T’’ is 30 Ib. ft. Therefore 30 pound foot of Torque will be applied at the fastener when ‘‘RS’’ is 20 pound foot. Note: If the torque wrench reads in pound foot, then ‘‘T’’ should also be in pound foot. ‘‘T’’ and ‘‘RS’’ should be in the same unit of measurement. ‘‘A’’ and ‘‘B’’ should also be the same unit of measurement. Hope this helps or just muddles the waters. if the torque is 25 ft/lbs, I don't think this matters much.
08 Cayenne Turbo |
Senior Advisor
just some more torque fun, doesen't really apply in this case, just for extentions FWIW
08 Cayenne Turbo |
It should be understood that this does NOT really apply to "extentions" but things along the line of a crowsfoot such as you'd use for old style cam nuts. Only an attachment that increases the overall length of the torque wrench has this effect.
Senior Advisor
like a "extention"
08 Cayenne Turbo |
Senior Advisor
like this one, B in the diagram
08 Cayenne Turbo |
