Very Interesting Carrera running problem and the solution!
I have a test for the Pelican brain trust of Carrera strange running problems. This is no hypothetical test. It is what happened to me and my 1985 Carrera this weekend. There are lots of other possible solutions and I will only address what happened to me.
To set up the test and the reality of what happened to me, I will try to keep it short. The car was running at 100% normal all last week. I drove it every day. On Saturday morning after 10 minutes of running on a cool wet day as left a stop light, the car just died like I did not know how to drive a manual. Start up, and everything is normal. Drive for several short trips, off to eat lunch. As I pull into the parking lot it dies. After lunch I go for home and I have no problems. I figure it is the classic DME relay problem. Replace DME relay, drive around the block and all is well. Sunday morning is Autocross day. As I head to the autocross site at 70 MPH on the interstate there is a momentary shut off of the engine, like someone turned off the ignition for a hundredth of a second. At the site as I am warming up the engine to get to 185 degrees the engine just dies several times. I make my run at full engine temp and the engine does that same quick off-on. I pack up and head for home. On the way home it does it twice more. My first thought was the DME itself. I pull the DME and look for bad solder joints. No problems that I could see. I then call a friend that works at a shop so he shall remain nameless. He brings over a known good DME. No difference. We swap the air flow meter. No difference. All of that points to the tach and speed sensors. The good news is that I have a set of new sensors in my garage but I have just not done the work to replace them. We did that and still no cure. I will leave it there. What would you try next? I will post the answer to what fixed my problem tomorrow. I want to see what you would suggest next.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Checked out
I'd use a multimeter to test the cylinder head temperature sensor. Check its resistance at cold, warm and hot to see if it is in spec.
Porsche 911 SC, SAAB SPG
I would first check the battery terminals and all of the main ground points...
My next check would be the coil and fuel pump wiring.
Jeff C |
Member 911 Anonymous
Sounds like an electrical issue.
Bad Ground or Loose Battery Connection?
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
3.4 Bigger is better
Another thing to check is to make sure all the plug wires are connected tightly on the spark plugs. That sound like what happened to me this last weekend. #6 wire had come loose at the track before and last weekend I had a miss which would cause the tach to drop off momentarily then everything was fine for short while, then another miss. It was the #6 wire loose.
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
I was sure it was a electrical issue, fuel issues usually don't cause the instant on/off running.
I replaced the head temp sensor a year ago with the two wire style. At that time I also replaced the 02 sensor. While the rubber grommet was off to replace the tach & speed sensors we checked that the head temp sensor was tight. The battery is only 6 months old. The posts are solid and the connections are tight. While the air flow meter was off we replaced the thermostat O-ring. That had nothing to do with the problem but it was leaking. I will post the solution to my problem this afternoon.
dme
loose intake bolts=air leak
GAFB
After the stuff you looked at, other low-hanging fruit for testing are alarm, grounds, coil, and ignition switch.
Several BMWs |
Coil wire loose? Electrical portion of ignition switch, lotta keys on keychain?
MBruns for President
coil, loose ground, spark plug wires loose.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Marmots?
88' Carrera, Black/Black/Black, "Murdered Out" OEM. 06' BMW 'M' Roadster (Wife's car and WAY faster than mine) |
Caveman Hammer Mechanic
Primary/points wire!
eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Overcharging alternator...
I think this killed my DME a few years ago. Same symptoms. Then it got worse.
Nick '85 Carrera |
Dme
The signs of overcharging are tach jumping and erratic and seat belt warning lite will come on intermitently
I didn't get those, but I lost a radio amp. Then I checked the volts - over 17.
A month later, weird engine running issues, then I finally replaced my DME after all sensor checks at the sensors, then sensor checks at the DME wiring and engine speed sensor replacements.
Nick '85 Carrera |
Ignition switch, electrical contact side.
The answer is......
The coil. All the connections were tight with just very light corrosion. I have owned the car for 14 years. I know the coil is older than that. That is why I had a new replacement in my garage. In all the years I have driven I have never personally had a bad coil. I have seen reports on this board about the new Bosch coils made in Brazil are not as good as the German Bosch coils. All that Bosch sells is the made in Brazil versions. I may go shopping for a high quality replacement.
N-Gruppe doesn't exist
yes a hot old coil could do that...my teener had that problem till a full tune up INCLUDING the coil.
Ted '70 911T 3.0L "SKIPPY" R-Gruppe #477 '73 914 2.0L SOLD bye bye "lil SMOKEY" ![]() "Silence is Golden, but duct tape is SILVER.” other flat fours:'77 VWBus 2.0L & 2002 ImprezaTS 2.5L |
muck-raker
As long as we're on the subject of poorly-made Bazillion coils ('cause there's a bazillion of 'em)...
Let's solicit the experts on their choice(s) of well-made alternatives. Do any exist, or are we stuck with these POS?
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
I would have won the prize. I know the SC is a different beast but my problems started much the same. Actually shut down several times during DEs. (There are several posts by me requesting help.) First I disconnected the rev limiter. No help. Then I replaced the electrical side of the ignition switch. Finally I saw in a random post that a coil that is on the way out would act like this. I replaced mine a few months ago and haven't had any trouble since.
Kevin '79 Coupe |
