build your own !
wanted to share my latest project. Custom built headers for my 3.6 transplant project (going in my 82' SC). They are 1 3/4" stainless-304, 0.065 ga., equal length, well almost, 18",19",18". Any Thoughts?
Old 11-03-2009, 08:02 PM
Tim K's Avatar
Nice work!
Any details on the little tube fixtures? I assume you're back purging while welding correct?
Again, nice work.
Tim K
Old 11-03-2009, 08:21 PM
tangerine911S's Avatar
Saawwweeeett!
Old 11-03-2009, 08:27 PM
80-911SC's Avatar
you sir , have skills , there are many here who would pay dearly for those , they are a work of art , almost a shame to put on the bottom of a motor ....
one idea is to carry a couple of mirrors and put them down when you park to show off your work ... truly nice .
Old 11-03-2009, 08:46 PM
Danny_Ocean's Avatar
Nice!
"Build my own?" Yeah, right. I would have better luck doing my own open heart surgery.
Old 11-03-2009, 09:15 PM
Fantastic!!
Do you have a picture of the complete system?
Old 11-04-2009, 02:41 AM
spence88mph's Avatar
sensational, man I want to learn how to weld, I have no idea where to start...
great work!!!
'89 911 M491+Turbo
'90 964 C2
'89 944 Turbo
'88 928S4
Old 11-04-2009, 04:11 AM
docrodg's Avatar
Hard to see the clearances in the pics, but could you sharpen the bend in the middle pipe and move it down enough to take an inch off where it meets the head?
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 11-04-2009, 04:13 AM
MBruns for President
JeremyD's Avatar
You'' probably need a bigger flange where the exit the heads - but excellent work there my friend. How much?
Old 11-04-2009, 04:43 AM
Very nice!
What muffler are you using?
Is it a straight through?
Hoping it is not an X flow muffler.
Old 11-04-2009, 07:10 AM
yep, im slow in the head
carslutt's Avatar
Send a message via Yahoo to carslutt
looks good, what is the orange tube? looks like a really nice way to mock up exhaust.
1978 911sc Targa - CNC plasma/router cut parts, tig welding, sheet metal work, VAG-COM, LM-1. let me know if u need something
Old 11-04-2009, 08:38 AM
Wavey's Avatar
Holy..... Nice work!
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar.
'11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX.
Old 11-04-2009, 09:30 AM
Crotchety Old Bastard
RarlyL8's Avatar
Your primary tube design is similar to mine. Back purge is not as critical in a non-turbo application but you would not want to suck in any slag during decel. I assume you are welding this up.
Old 11-04-2009, 09:47 AM
Very nice work sir !!!
++++1 on more info about those clamps holding the work prior to welding - I've never seen them before, and they look like very usefull little gadgets !!!
John
Old 11-04-2009, 01:11 PM
All,
The "kit" I used was purchased from a company called "icengineworks" it came with dozens of various pieces (different radius & straights) and the welding clamps you see in the pictures. It took me about a week and several attemps before I got them to fit & equal length. The muffler is a Magnafold "X" flow type at about 14" wide. Somebody said the "x" flow may not be good?? and I think I could have gone with something wider (like 20" wide) and thus less loud?? Any suggestions on olive connector or straight flange type after the merge collector??
Old 11-04-2009, 06:06 PM
This it my belief or two cents on the X flow. It was not intended to be used with exhaust gasses coming at each other where the tubes cross. It is more intended as a cross over and muffler for a car with a V6/8 where the tubes and gasses are running the same direction.
If you are intent on a Magniflow style muffler there is one that has two straight through tubes. This has been used with one side of the motor going through the upper passage and the other thought the lower tube in and out.
They also make a Camaro muffler that has two 2.25" In's on each end and one 2.5" out on one end.
Your design is perfect for a Flowmaster muffler which is designed with an In and Out on both ends of the can. It is a proven race muffler on a 911 and makes power but can drone with its two tail pipes.
Old 11-04-2009, 06:47 PM
Band.
Originally Posted by RarlyL8 View Post
Fix that sump plate, sonny!!!!
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 11-04-2009, 06:50 PM
Navin Johnson
TimT's Avatar
just check out
Ice engine works
Probably cheaper to use some mild tube for mock up..
It modeling blocks...Ideally you use sections of off the shelf tubing....
'69 911 GT-5
'75 914 GT-3
and others
Old 11-04-2009, 07:05 PM
Header Lego....great concept
Old 11-04-2009, 08:37 PM
ALXinNZ's Avatar
Where are you going to mount the lambda sensor ? Can the wires be lengthened ?
Regards
Old 11-05-2009, 03:11 AM
