Heat exchanger interchangability?
Quick question. Will a 3.2 stock heat exchanger setup fit a 3.0 SC engine?
Thanks.
Aloha, Rob
89 911 Silver Ann.
Old 12-16-2009, 09:02 AM
nope. you gotta mod the HE's. the lip or insert that protrudes into the head on the 3.2 HE's is too big to fit into the 3.0 heads.
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 12-16-2009, 11:53 AM
Ok so aside from cutting off that lip the exchangers will line up and bolt to the heads?
Have you done this before?
Just looking for a quick fix for a friend.
Thanks.
89 911 Silver Ann.
Old 12-16-2009, 12:38 PM
palle7688's Avatar
I've SSI's from a 911 SC on my 3.2, so yes the distance between the cylinders are the same.
But the flanges on the 3.2 heatexchangers are thicker and the bolts on you friends SC is not long enough.
You might not be happier owning a Porsche, but it certainly feels so driving one
Old 12-16-2009, 02:23 PM
Ok thanks for the replys. I think we can make this work.
89 911 Silver Ann.
Old 12-16-2009, 02:34 PM
You can make it work but you will need the longer exhaust studs and cut the flanges of the HEs.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS
Old 12-16-2009, 03:11 PM
yeah itll work. you may already have the long studs, i did. to get it to seal up well i filed the gasket mating surfaces flat.
Jason
81 SC
97 328is
Old 12-16-2009, 03:29 PM
shbop's Avatar
How about stock 3.6 exchangers on to a 3.2?
Jon
Old 12-16-2009, 05:05 PM
