fixing broken piston rings
forgive me for my ignorance but what is entailed to fix a broken piston ring? can you just fix the cylinder with the broken ring? does the case have to be split? ballpark on cost to fix? i'm getting alot of crankcase pressure in my oil tank and did a search which indicates this may be the problem. car runs fine and just got it back from mechanic who said this was a normal situation but the car smokes on startup and after hard accelarotion on boost. car is a 1983 930 with maybe 6,000 miles on rebuild. any thoughts would be greatly appreciated. mick
Old 12-21-2009, 02:31 PM
Senior Member
Superman's Avatar
Was the rebuild done at Motormeister?
Mocha 1978 911SC. "Coco"
Old 12-21-2009, 02:40 PM
no, a reputable company.
Old 12-21-2009, 02:49 PM
Quantum Mechanic
mpetry's Avatar
Send a message via Yahoo to mpetry Send a message via Skype™ to mpetry
Well a compression test first will tell you which cylinders are questionable.
If you decide to replace the rings, then the engine must come out, take everything apart, and the heads come off. Then you can replace the rings, after sliding the jugs off the pistons.
Maybe it's just me but if I had suspect rings after 6000 miles, I'd be tempted to replace them all.
Then re-assemble everything, get it reinstalled and running right. It's essentially a top end rebuild, minus the valve job, assuming you don't find anything else broken...
good luck with it
Mark Petry
Bainbridge Island, WA
81 SC
Old 12-21-2009, 02:52 PM
UnRegistered User
billybek's Avatar
Is it possible that the restrictor in the sump vent line is plugged or the line installed improperly?
Just wondering if your crankcase is pressured up for another reason.
+1 to a compression test and leakdown.
Could be that the rings never seated...
Bill K.
Old 12-21-2009, 02:58 PM
Senior Advisor
James Brown's Avatar
WOOOOH there Mickster, lets not jump off the cliff quite yet. There are several things that can cause that condition that must be eliminated first. leak down test being first, pull the exhaust off and see if there is any oil coming from the exhaust valve guides, check the lower valve cover gaskets looking for leaks, oil return tubes......See where i'm going? many things mimic rings but aren't that hard to fix or as costly.
Nice looking engine there, Mark (like your cylinder holders, cheapskate!!!)
08 Cayenne Turbo
Old 12-21-2009, 03:06 PM
thanks for all the responses guys. the reason i thought it might be the rings is that it turned up in a search i did concerning crankcase pressure. i'll definately leakdown/compression test done to eliminate the rings. mark, thanks, that was the explanation i was after. the thing that's weird is that it runs fine. hopefully it isn't the rings. thanks again.
Old 12-21-2009, 03:48 PM
overboost/detonation can certainly break rings into little pieces. what's your boost limit? there's a ball bearing in the fitting that the turbo oil feed line attaches to on the case. without it, you can get some smoking.
206 637 4071
Old 12-21-2009, 05:55 PM
boost limit is .8bar. is that line easy to get to and check? thanks john.
Old 12-22-2009, 02:46 AM
you can do it with the engine in the car. intercooler, A/C pump and air filter housing off, then find the red oil pressure light switch over the bellhousing. remove the switch and then the big fitting under it that goes through the banjo end of the oil line. then dip a skinny magnet into the big fitting below that and see if you come up with a ball bearing.
206 637 4071
Old 12-22-2009, 05:29 AM
smokintr6's Avatar
Send a message via AIM to smokintr6
How have you measured pressure in your oil tank? And, are you sure all the breather hoses are hooked up properly?
It is actually pretty normal for these engines to smoke on startup... Even a relatively new one. Smoke during and after hard acceleration can be the result of several things, including rich fuel mixture. Have you verified any oil consumption? Good luck, and check back with us after your leak and compression results. It might be prudent to have a different shop (who did not build it) check the engine's condition.
Old 12-22-2009, 05:30 AM
beancounter
jwasbury's Avatar
I had lots of crankcase pressure on my 930, it would actually puff like exhaust out of the oil filler. Car ran great, no visible smoking under boost.
I found 44% leakdown on #6, and busted rings on 3 cylinders:
Overboosting can happen due to faulty wastegate, and overboost switch disconnected (a "mod" that is too often done by dumb POs). Also carefully check ignition timing at full advance and make sure vacuum/boost connections to the dizzy are properly set up. You can use a mity vac to test. If any of this stuff is not right, you end up with the 48 piece piston ring.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 12-22-2009, 08:11 AM
midnight911's Avatar
my 84 3.2 lost compression, losing the ring in cyl 6. My fix was to get a 3.6 motor...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 12-22-2009, 09:56 AM
Senior Member
Superman's Avatar
I used bits of garden hose.
Old 12-22-2009, 11:28 AM
gonna do a leak down test as soon as some of this snow disapates. hoping not to find what jacob had.
Old 12-22-2009, 01:40 PM
any others things that could tell me if my rings are broken? it's kinda keepin me awake at nighy. might be some time before i can get it to a mechanic.
Old 12-22-2009, 02:27 PM
Walt Fricke's Avatar
Mick
The leakdown test will tell you a lot. It will tell you if the seal of one cylinder differs significantly from that of the others. Then it will tell you where the air being fed into that cylinder is getting out. You just listen - intake valve leaks come out the intake, exhausts you hear loudest at the end of the tailpipe. Ring leaks show up as air escaping into the crank case. You want to listen to the crank case (run a small plastic tube from your ear into the oil filler tube with the cap off) for all six of your checks, because there is always some air leaking into the crank, and you are listening for a louder sound from one cylinder than the others. If they all sound the same, they probably are all OK.
In normally aspirated engines, one cause of broken rings is worn ring lands - where the rings fit in the pistons. If these get too wide, the rings can wobble around, etc. You might check to see if the rebuild included new pistons, or a careful measuring of the ring grooves before deciding to install new rings.
Listen to these other guys on turbo specific issues.
You don't sound like you are a home brew mechanic, so the question put to you about how it is you know what your crankcase pressure is is a good one. Did you create a tool to measure it with a gauge? I think I could figure out how to do it, but don't think there is a spec for this. Crank pressure vents into the air cleaner/intake system, so it can't ever be very large (even though a little pressure can move a lot of aereated oil mist).
You just won't know until you do some measuring and the accompanying listening.
Walt Fricke
Old 12-22-2009, 06:26 PM
walt, thanks for the info. i just have to wait to get some time to bring it to my mechanic. we just had alot of snow so i'm waiting for that to melt to. anyway, i'll post the verdict as soon as i get the results. thanks again, happy holidays.
Old 12-25-2009, 11:01 AM
Grand Am/IMSA Data Guy
Porsche84's Avatar
Mick
My 84 (non turbo) had alot of pressure in the crancase two times. Both times I found broken ring (actually shattered into small pieces). The second time was with only after 1000 miles with new piston and cyl (Mahle euro). My problem was detonation due to no vent in the gas tank (creating too low fuel pressure at high RPM). That was pretty much my most expensive lesson, thus far, on the 911. Pretty sure you'll find shattered top piston rings.....sorry
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 12-26-2009, 03:48 PM
