weber carb setup stupid questions
what is the best way to setup the fule lines? do i need to run a return line? is it better to run the carbs in series? how bout a pressure regulator? I am setting thes up for my 914_6 project. and i want to replace the fule lines...
Old 01-10-2010, 04:20 PM
Senior Advisor
James Brown's Avatar
Did you try the 914 board?
08 Cayenne Turbo
Old 01-10-2010, 04:38 PM
Emery,
Carburetor installations like return lines, ala 914/6, which really helps prevent vapor lock in hot weather.
A pressure regulator is mandatory for Webers as they MUST have 3.5 psi.
Carbs are fed in parallel from the FPR,....again, look at pics of the 914/6 as a general example.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 01-10-2010, 05:15 PM
Thanks steve for the input.
Old 01-10-2010, 06:13 PM
'73 911 T Targa
I set mine up using a spin-on fuel filter for a boat. It has multiple connections, with two outputs, allowing me to use one for each carb. I come into the filter from the tank and use the other input for the return with a valve in it to constrict flow back to the return, thus regulating the pressure to the carbs. I put a gauge between the filter and the valve so you can see what the pressure to the carbs is. Then, I take one of each of the outputs to each of the carbs. I though it made for a nice neat installation. By the way, if you adopt this, don't use the filter with the plastic bowl. Here's a diagram
Old 01-10-2010, 07:21 PM
