Eye of the Toiger
matty74's Avatar
what is the diff between 3.6 Vs 3.0 fan?
I got a 3.6 long block and it is missing the fan/alternator, so what is the diff between 3.6 Vs 3.0 fan? is the 3.6 fan 11 blade?
bit of a pain in the but finding these parts
http://www.aircooled.com.au
1973 911 RSR clone powered by 77 3.0 turbo
Old 02-07-2010, 10:04 PM
Max Sluiter
Flieger's Avatar
3.6 has re-curved vanes for less noise at the expense of less efficiency and flow. Forward-curved blades would actually increase efficiency from what I hear. Too bad you can't run it backwards.
I think the diameters are the same so that a 3.6 fits a 3.0 housing and t'other-way-round.
Some expert should check me on these points, though.
Old 02-08-2010, 01:08 AM
Eye of the Toiger
matty74's Avatar
ok so I can use a 3.0 fan on a 3.6.
Old 02-08-2010, 01:42 AM
