I am so jealous of your solid shell, painted.
Feels so far away. Love the colour. |
Keepin' it Simple...
Man that was a lot of work...
Tough to say whether the electrical work or the fuel lines took longer, but I do know the fuel system was not cheap! All aluminum lines and AN-6 fittings.
The rear end is now ready for the powertrain... everything that can/should be done is buttoned up. The cam sync sensor wiring and injector harness wires have to wait and can be seen in the front left corner of the engine bay. All the other sensor wiring is harnessed and ready to plug in: ![]() ![]() ![]() ![]() Once I get front suspension parts back from the powder coater's, I can get the car on all fours and proceed with the nuptials!
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) |
Rennch on YouTube
Mmmm, I've missed this! Looks like I'm just arriving at the punchline.
Michael O'Neal - 69 RSR Clone(ish) - The build: http://bit.ly/69porschersr 69 911S Blasphemy Build on YouTube Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/ |
What hose are you using from tank to catch can? I can't find one that flexible.
Todd
'81 SC |
Hope that helps,
The happy couple...
Got the powertrain in about a month ago! Enjoy the pics, you know the drill...
![]() ![]() ![]() Always surprised it actually can fit. Nice to have some more floor space in the shop!
One month into it and still connecting the dots
Mechanicals have gone well save one snag on the front oil cooler stuff. Put that on the back burner and focusing on the top side engine bay electrical. I did so much prior to engine install, have done a bunch more now that the motor is in, and STILL have a bunch to go
! Don't take this EFI thing lightly if you jump off the bridge... it is a lot of work. Gotta be patient!Pretty hard to tell by the pictures, but I am down to the cam sync sensor run, shortening the O2 sensor lead, and building the fuel injector harness: ![]() ![]() ![]() ![]() ![]() ![]() The fuel system is finally done (thanks Len) and Mr. Clewett is helping me avoid the land mines. They are two patient guys. Thanks for following along...
Signs of Life...
It took most of December to get all the engine wiring finished up. Finally, finally time to install the battery and see how things look.
Been here before, but always nice to see lights: ![]() But this is new territory: ![]() Good news is all the EFI sensors were alive and well! Big hurdle cleared so onto the next. Fuel system checkout. Gas guage/sender still works right: ![]() Trying to avert a mess/just in case: ![]() ![]() ![]() I already knew the fuel pump wiring was all correct, so just gotta turn the key and hope for the best ...RESULTS: Only one tiny leak presented itself, but was easily fixed. What a relief! LOTS of custom work required just to see this number register on the gauge: ![]() Not too much left on the pre-start to-do list....
Fired right up...
It's alive and well! I took a video, but no way to post it, so a blurry fan picture will have to do:
![]() No real drama to speak of, which of course is a good thing when you run a new motor for the first time. No leaks to report after the 20 minute run-in. Awesome to see the gauges doing their thing: ![]() There will be plenty of EFI tuning to do later, but for now I had to dump the oil. I already can't wait to hear that R muffler again and rev it a little more. All the parts are finally in hand to complete the front oil cooler setup, so that is the next big item on the to-do list...
As I read this, I am smiling from ear to ear. What a great story. WELL DONE !!!!
Porsche Nut
Awesome on the starting. 👏 Is that fuel line across the motor staying as is?
Scotiagreg
Looking great Doug! It won't be long now before she's roadworthy. I put over 5000kms (3000miles) on my 68 this summer with nary a hiccup. Sooo much fun to drive !!
1963 356B, 1968 hotrod 912/6 1985 Carrera, 1992 Carrera 2 Targa 2005 Boxster S, 2017 Macan S |
fuel line
Another option I thought about was to have Len make me a rubber line with 90's on the ends and clamp it to the top of the fan shroud at the 2 studs. Thoughts/concerns?
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) Last edited by R_Builder; 02-05-2015 at 03:34 PM.. Reason: typo |
Thanks Greg. Putting in the time and counting the days. Glad you are so happy with yours... it turned out great.
ok- looking pretty nice Doug !
regarding the aluminum line: It looks nice, but there is no give going point to point solid tubing. I would prefer to see at least one end with a fuel rated piece of hose between the carb and the line. also if you fasten it to the shroud, let it float in the locating clamps. The constant expansion and contraction, of the solid tube is a recipe for a failure in the future. Full on race cars, that use solid tubing are always being taken apart and inspected, so you can't use those as examples to follow
1970 914-6 street"evil cockaroach" 1970 911 Targa "ST" Jade Green IROC Tribute (ready to race) |
1983 Porsche 911SC Blk/Blk 1956 Ford F1 - Patina 2013 Toyota Tundra 4x4 5.7 2013 Honda Pilot |
R hinges are external on Doug's car. See pics below of other R's. Besides that if Doug was using stock hinges, those would clear the PMO air cleaners too
Can you believe it... it is finally getting close! You have been along on the ride from almost the beginning and it is much appreciated!!!!
-Doug 1968 911R Clone; 11/07-?? (forever the project car )1978 911SC Midnight Blue Metallic Coupe; 7/05-11/09 (so long impact bumpers) 1973.5 911T Sepia Brown Coupe; 9/98-8/99 (went to a great home) 1973.5 911T Gulf Orange Targa; 5/97-11/02 (went back to Germany) Last edited by R_Builder; 02-05-2015 at 09:34 PM.. Reason: typo |
(man/dude)
I like the line - a nice touch. Definitely needs some clamps, and the point on vibration/cracking is valid. As long as it's well supported and not under stress (ie do the ends align perfectly with the fuel rails) I think it would be ok.
Nice job on the car!!! |
Time for some updates…
February turned out to be front oil cooler install month for me. Pretty much all factory SC/Carrera vintage parts except for Chuck’s high clearance lines in the back and some custom bracket work up front. Always “fun” to do this on a car that has never had a front cooler
. This install put up more of a fight than usual because of parts availability issues, fitment issues with my chassis, items damaged in shipping, undercoating touch ups, fender painting, blah blah blah. Very glad it was finished and pleased with the results! A lot of us have been to this rodeo before so I’ll just show you the answer (from front to back):![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Love that last picture. Seems like they were designed to fit there...
