Missing engine serial number
I need to pick the collective Pelican brain. I have been looking for the engine serial number on my 72 T's engine but have come up empty. I've been told that it is supposed to be stamped into the vertical fan support on the right hand aft of the engine. My owner's manual confirms that it should be there. My engine does not have any evidence that there ever was a number there. I cleaned off some slight corrosion with a brass brush and some thinners only to find a smooth surface underneath. Even shining a flashlight at different angles doesn't reveal a stamping or even traces of its removal.
The only stamping I've found in that area is 911/57. Anyone have any ideas? Is there a second stamping elsewhere on the engine that I could look for? Help! ![]()
1979 911SC "Frankencab" Dave |
If it were to be a 914/6 case the numbers would be stamped by the breather and thermostat.
In the years there was some porus cases in the area of the oil pump and were replaced with unstamped cases by the dealer. Bruce |
No stampings around the breather so I guess that rules the 914/6 idea out. Tried to check the date code but it's buried too deep behind the engine mount brackets to see even with a small mirror.
sudo apt-get purge 930
Factory replacement cases came without numbers. I would suspect your engine was either replaced or the case was replaced at some point due to engine failure.
Mark 1979 930 Euro ***GONE AND DON'T MISS IT AT ALL*** "Worrying about depreciation on your car and keeping mileage down is like not ****ing your girlfriend so her next boyfriend finds her more appealing" --clutch-monkey |
Capitalist and Patriot
My book shows:
911/57 as a 1973 911TV-E (not sure what TV-E means, maybe Sportmatic?) 2341 cc, 130 hp @ 5600 rpm & 196 tq @ 4000 rpm, Carbs, bore/stroke = 84/70.4, 7.5:1 cr, valves int/ex = 46/40, ports int/ex = 32/32, engine# 653001 Hope this helps!
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
You have a factory replaced case, I had one on my 73E and also on a 66 912.
Bingo! Replacement cases have no engine number because they are a replacement part, not a complete engine. Not a big deal unless you are into the "matching numbers" thing. It just means that your engine is not original, tho it may well be rebuilt to original specs...
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) Last edited by pwd72s; 02-01-2010 at 12:02 PM.. |
