exc911ence's Avatar
Missing engine serial number
I need to pick the collective Pelican brain. I have been looking for the engine serial number on my 72 T's engine but have come up empty. I've been told that it is supposed to be stamped into the vertical fan support on the right hand aft of the engine. My owner's manual confirms that it should be there. My engine does not have any evidence that there ever was a number there. I cleaned off some slight corrosion with a brass brush and some thinners only to find a smooth surface underneath. Even shining a flashlight at different angles doesn't reveal a stamping or even traces of its removal.
The only stamping I've found in that area is 911/57.
Anyone have any ideas? Is there a second stamping elsewhere on the engine that I could look for? Help!
1979 911SC "Frankencab"
Dave
Old 02-01-2010, 08:06 AM
If it were to be a 914/6 case the numbers would be stamped by the breather and thermostat.
In the years there was some porus cases in the area of the oil pump and were replaced with unstamped cases by the dealer.
Bruce
Old 02-01-2010, 08:11 AM
exc911ence's Avatar
No stampings around the breather so I guess that rules the 914/6 idea out. Tried to check the date code but it's buried too deep behind the engine mount brackets to see even with a small mirror.
Dave
Old 02-01-2010, 08:31 AM
sudo apt-get purge 930
equality72521's Avatar
Factory replacement cases came without numbers. I would suspect your engine was either replaced or the case was replaced at some point due to engine failure.
--clutch-monkey
Old 02-01-2010, 09:31 AM
Capitalist and Patriot
911Freak's Avatar
My book shows:
911/57 as a 1973 911TV-E (not sure what TV-E means, maybe Sportmatic?)
2341 cc, 130 hp @ 5600 rpm & 196 tq @ 4000 rpm,
Carbs, bore/stroke = 84/70.4, 7.5:1 cr, valves int/ex = 46/40, ports int/ex = 32/32, engine# 653001
Hope this helps!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 02-01-2010, 10:21 AM
exc911ence's Avatar
Originally Posted by 911Freak View Post
My book shows:
Hope this helps!
Thanks. The book "Original 911" by Peter Morgan shows that the 911/57 engine type was used in the 1972 and 1973 911 T coupe and targa models (non-Sporto) only. That tells me that the engine is at least correct for the car, if not the factory-installed one.
Dave
Old 02-01-2010, 10:54 AM
You have a factory replaced case, I had one on my 73E and also on a 66 912.
Old 02-01-2010, 10:56 AM
pwd72s's Avatar
Bingo! Replacement cases have no engine number because they are a replacement part, not a complete engine. Not a big deal unless you are into the "matching numbers" thing. It just means that your engine is not original, tho it may well be rebuilt to original specs...
Old 02-01-2010, 11:00 AM
