UNDER CONSTRUCTION!
how much blue RTV does it take to seal up your case
allot
and i mean allot ![]() i took the car for a drive and it ran good but shifted poorly, i asked him if he had a PPI done he said why should he the porsche dealer sold it to him. we took it into the garage for a quick look over and found that the bottom of the case was oozing oil and blue RTV.after a bit more inspection i found the whole motor had been sealed with this stuff. i told him to take it back and ask how this made it past inspection and he was told it was as is. but they did fix his sunroof apparently this wasn't as is?. so as you might have guessed im resealing the motor the bearings and crank look good after a mic i have decided to clean crank and install new bearings seals. i am now 18 hours into cleaning and still not even close to being done. long story short getting a second opinion would have saved a lot of work money for him. well i normally don't post anything like this but i came in from garage upset about how hard it is to clean off the RTV. so after the motor ill tear down the tranny and fix that as well. sorry for the vent but had to get that out. cheers ed
Sometimes the first thing that comes to mind should be the last thing that you do! ![]() Last edited by carrera turbo; 02-09-2010 at 11:01 PM.. Reason: tried to add pics |
UNDER CONSTRUCTION!
Removing the stock thermo reactors and replacing with an updated SC system. also had a little help in the tear down.
cheers ed ![]() ![]() ![]() ![]() ![]()
Sometimes the first thing that comes to mind should be the last thing that you do! ![]() |
Northern Motorhead
That blue stuff looks like some sort of jointing compound ... Hylomar or another brand,it's not supposed to harden but rather stay flexible,obviously whoever used it put way too much although he should not have used it in the first place !
What a mess ... Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
a 2.7 with new main bearings will most likely bind the crank when the main through bolts are torqued up. read up on what needs to be done to a 2.7 case if it's to be reused. maybe you already know. those engines are nice when properly rebuilt, but a can-o-worms otherwise.
Virginia Rocks!
Why does that happen?
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
The mag case warps. Soon as you split the cases, they will spring a little. All mag cases are prone to this, it's just that a hot running 2.7 with thermal reactors does it the worst. That, and its spiggot holes are the biggest of all the mag cases, so that contibutes to their tendancy to warp. So, before it can be put back together, the mating surfaces need to be faced off true, then the mains need to be line bored.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
I soak parts in Bar-sol that have any kind of silicone sealant on them. It will turn it into a goo that will wipe off. Leave it in the parts cleaner over night. You know if you have the right stuff by putting on a latex glove and getting some of the Bar-sol on it. The glove will grow and eventually disappear.
Lindy |
Bill is Dead.
Barton Solvents Inc.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
UNDER CONSTRUCTION!
![]() Quote:
cheers ed
