Pierre911SC's Avatar
Smile Does SSI overheat engine ?
Hello,
I own a 82sc with headers, which mean no heat in the habitacle. I live north of Montreal and want to use the car a little longer during the fall period as the weather gets cooler(defrost & foot well heat).
I am now in the process of upgrading the engine to a 3.2ss with SSI.
I have removed the rear blower.
I have read some threads, about overheating the engine, if there is no
air circulation in the heater boxes of the SSI !!!
Any opinions or comments.
Regards
Pierre
stsrobotic@yahoo.ca
82 911SC wide body, 3.6L
Old 02-11-2010, 11:50 AM
304065's Avatar
Pierre,
Yes, if you use SSI heat exchangers, you should hook up the heater inlets. Heater backdate ducts are available for the engine shroud, as are the clamps and hoses. On the outlet side, if you don't run heater hoses to the heater valves on the body, you should install air restrictors per the factory workshop manual to keep the back pressure up.
Search here for "heater backdate" for more information. SSI heat exchangers are of extremely high quality.
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 02-11-2010, 12:12 PM
Thank you John, I found the informations.
Regards
Pierre
stsrobotic@yahoo.ca
Old 02-12-2010, 09:52 AM
Northern Motorhead
wildcat077's Avatar
Hey Pierre,
I have to admit the heat is nice,especially driving home from Mt Tremblant on a cool November evening ... lol
Good luck with your project !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 02-12-2010, 01:04 PM
