Unhappy Front end vibration between 85-120 mph?
Have a 1981 911SC, with Bilstein HD shocks, turbo tie rods, Kumo tires, lowered and aligned for DE events with camber strut brace.
Runs very smoothly, however, between 85-120mph I get strong vibration in the front end - strong enough to make your eyeballs bounce around so one has trouble maintaining focus on the track - not good...Suggestions as to what to inspect, test or change?
Old 02-13-2010, 01:42 PM
DanielDudley's Avatar
Check your tires and balance first
Old 02-13-2010, 01:48 PM
muck-raker
kidrock's Avatar
+1, check your tire balance.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 02-13-2010, 04:10 PM
Grady Clay's Avatar
+2 but I suspect a flat spot.
Best,
Grady
ANSWER PRICE LIST (as seen in someone's shop)
Answers - - - - - - - - - - - - - - - - $0.75
Answers (requiring thought) - - - - $1.25
Answers (correct) - - - - - - - - - - $12.50
Old 02-13-2010, 04:18 PM
PRO Motorsports
Tyson Schmidt's Avatar
I have lost my wheel weights on my racecar countless times. The tire guy at the track uses tape to try to keep them on, but it too melts, and the weights fling off.
They only stay on if I remember to put the aluminum tape over them when the tire guy is finished.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 02-13-2010, 04:20 PM
Drive at 84 MPH or at 121 MPH
___________________________________________
2001 Boxster S, Orient Red Current Vehicle,
1973.5 911 full factory "S" trim with a 3.2 engine **Sold**,2002 996 **Sold**,1975 911S **Sold**,
1971 911T **Sold**, 1968 912 **Sold**
Old 02-13-2010, 04:37 PM
