Carrera tail
Here is a pic of my July 74 built Carrera #19.
The tail was installed at the factory, I visited the Museum a month ago and Turbo#1 has the same tail with Carrera emblem. Built the same month as my car. See pics. ![]() ![]() ![]()
Momo collector
Carrera Whale Tail
Carrera Whale Tail available for sale, good condition incl rubber & heat shield.
If interested, send a message
Mads from https://www.patipatina.com |
Momo collector
Sold
and the old "Z" license plate (Z stand for Zoll, customs), stating that it is ready and declared to leave the country
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
The tail with the secondary grill first appeared on preproduction 1975 Turbos in Sep 1974. Here's '75 Carrera chassis #9115400012 that sold on BAT that has a very early whale tail without a secondary grill. https://bringatrailer.com/listing/1975-porsche-911-carrera-10/ Love the color of your car. |
A little bit hard to see in the pic's, but a brand new SC in 1979.
Momo collector
Anyone looking for a small (2nd) grille? Let me know, have two that I no longer need .. Turbo's gone
Hello,
I am selling an original early style single grille whale tail. It is in perfect condition !
Do you have better pictures of the studs that mount the rubber to the base?
Hello,
What exactly do you want to see ? The rubber is perfectly mounted to the base. At this moment all studs are fine, no broken studs. Honestly I am not going to try to loosen them. Allthough they are not rusted as far as I can see, breaking the studs is not a risk I am going to take..... There are 4 studs at the back and one at each side left and right. Best regards Kristof |
Here’s a 964 turboS Lightwieght rear .
Porsche Motorsport part , carbon kevlar iirc . Also seen on some ruf cars . No , I’m not fitting an escort cosworth type wing on my 73 !!! It’s just a good place to store it until it goes back to the paintshop... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
My all original 82 SC.
Don't take them off. From the pictures on your ad. They look kind of like screws instead of studs
I'll have a look at it tomorow and try to take some extra pics.
Hello, you are correct, the rubber is bolted to the frame with 5 screws and one original stud. Must say the rubber fits perfectly and feels tightly fixed. They also seem to have used the original holes in the frame, I see no extra holes. I cant tell how they modified it to fix it properly with screws but it seems profesionaly done.
[QUOTE=ian c2;11001300]Here’s a 964 turboS Lightwieght rear .
Porsche Motorsport part , carbon kevlar iirc . Also seen on some ruf cars . No , I’m not fitting an escort cosworth type wing on my 73 !!! It’s just a good place to store it until it goes back to the paintshop... ![]() Where did you come by this tail? Is it factory or aftermarket? I had a factory 94 turbo S tail which was considerably larger and made of fiberglass. Many I know have been looking for good reproductions of the TSL tail but usually only glass or CF versions of the 3.2 carrera/964 RSA tail can be found. The TSL tail is larger. Does this have the shrouds for the intercooler as well? The factory 94 tail had no part number but a fiberglass resin blob with an OE equipment triangle impression on the inside along the backside. All I can say is that the TurboS tail sold for as much as an entire 964 donor car I picked up back in 2014.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
Let me look at a rubber I have to make sure of the original configuration.
Anthony ,
I think we might have spoken about your spoiler many years ago ? My memory is not very good these days , but iirc ... You had the 965 turbo S rear . This was a ‘tea tray” type spoiler like a normal 965 , and bolts to a normal 965 lid . Made of fibreglass , and due to shape of inlet area could not use the normal 2-piece grill . The 965 turbo S lightwieght rear is a “whale-tail” type spoiler Like a normal Carrera , and bolts to a normal 965 lid . Made of carbon Kevlar , and due to shape of inlet area Can Use the normal 2-piece grill . ( there is a strip of aluminium on inside for fixing to ) Mine is getting ready to go back for its 4th painting (had my uk car painted twice as first finish unacceptable to me , And had this redone ready to go on my USA car but needs redoing due to “storage problems” ) so I’ll look into cleaning it right down and snap some good pics . I think cargraphic made them for porsche Motorsport/special wishes , so it might be worth contacting them to see if the have one ? If not , porsche Motorsport or ruf . Morris made some Kevlar parts For pms too , so maybe try them . Ruf still use it , or a version of it , so they’d probably be the best bet Allthough I think they’re now using a carbon version and not carbon/Kevlar .. I cannot remember exactly where I bought it . I just looked at the intercooler ducting and it came from Mann island porsche in liverpool , and they where my contact to porsche Motorsport department , so I’m guessing it came from factory . ( I was installing 9.5” speedlines super-cup wheels at the time that where a Motorsport only part) Mann island was quite a distance for me especially considering I had other dealers much closer to home , so I would not use them just for “normal” parts ... To give an idea How long it has been , back then certain dealers could “speak” with the Motorsport department via fax ![]() Normally a couple of days after Mann island sent the fax I’d get a phone call from them that allways seemed to start with “are you sitting down ?” I want to say it cost me around 5000 uk pounds to get this on my car back then In the late 90s . It certainly was not cheap !! ![]() And Mann island shut down around 2000/2001 . EDIT : it might Even have come from steve strange as I just recollected he parted out a car once . Though I think I only bought the lower dash from him . Pics of black car below for reference of grill fixings etc came from silverstone auctions lightwieght , silver car showing x93 single piece grill is From road scholars turboS slantnose , last pic is the sticker from Mann island liverpool on my shroud (which I installed but didn’t Actually need as I never ended up converting to turbo) ![]() ![]() ![]() ![]() The weave is bigger than used on the hoods . See pics below . Photo with blue Kevlar by DuPont sticker showing is a hood . EDIT : Iirc Morris made the Kevlar hoods for porsche and ruf , and with the weave being different to the hood I suspect they will not be much use to approach . EDIT AGAIN : I just had a quick look and it seems the smaller weave is used in certain areas as well as the larger one , so maybe it is worthwhile to approach Morris . I was looking for a resin blob like you describe , but do not see anything . Do you have photos of this you can post ? ![]() ![]() [QUOTE=Cobalt;11002357] Quote:
^^ very nice and rare piece. Thanks for sharing. I had not seen a TSL tail before. Interestingly the part number you have is noted is for the air shroud I had no idea what that number was but apparently is still available. AFAIK the 94 tail needed a taller shroud for the taller wing I am assuming your is the same or that the TSL tail uses the factory part vs the 94 TS.
The tail I was referring to was the 1994 965 turbo S tail. It was slightly larger and made of FG. Here are some pictures of it. AFAIK mine was the last of this type of tail in existence in its original gel coat. I much prefer yours. ![]() ![]() The last pic is of the OE stamp I mentioned. ![]()
