-   -   The original OEM tail thread collective documentation (http://forums.pelicanparts.com/porsche-911-technical-forum/527702-original-oem-tail-thread-collective-documentation.html)
Tremelune 01-03-2015 05:33 PM
Does anyone have any photos of late 930 teatray tails compared to M491 teatray tails? I've read they're different. Maybe even between AC and non-AC...
ASTAR911 02-20-2015 11:10 PM
Finally got my hands on this wing.
I will post more detailed pics when I get a chance, it appears to be all FG and no sign of any numbers in the usual spots.
One thing I have noticed is a green colour appearing under the white paint.
Is this normal for FG or was this wing painted in this unusual green colour at some stage and maybe used on a "special" car in the past?
http://forums.pelicanparts.com/uploa...1424502583.jpg
rsnodgrass 02-21-2015 12:06 AM
That looks like a reproduction tail since the Turbo AC tails didn't have the support brace that went across the opening since the original tails had fan ducting where the brace in your photo is.
Ferrino 03-09-2015 09:52 AM
Does anyone have any intel on the fiberglass tail pictured below, please? I picked one up at the Anaheim swap-meet with the intention of bonding it to a steel decklid and would love to know the origins. It's a very sturdy piece and appears to fit a factory decklid very nicely. It has studs glassed into the base, so I guess it was intended to just be bolted to the decklid. I assume it's an aftermarket part? The profile of the tail and lip is a very nice replica of the factory Carrera/Weissach tail - obviously the rubber is now rendered in fiberglass. Thanks!
Originally Posted by Beschleunigt (Post 6740994)
I took this off a 71 911 that had been sitting since 79. It looks like its still in the original gel coat and hasn't been painted. It is all fiberglass with no rubber lip and was mounted to a steel decklid. I don't see any part number, so I have no clue. Any ideas?
https://lh6.googleusercontent.com/-u...0/IMG_0634.JPG
https://lh6.googleusercontent.com/-H...0/IMG_0635.JPG
https://lh6.googleusercontent.com/-B...0/IMG_0636.JPG
kristof 03-13-2015 12:48 PM
Hello
I've been reading through this topic recently.
I saw this ad on ebay and wonder if this is a realistic prize ?
Porsche 911 Euro Carrera RS Factory Spoiler | eBay
Gib Bosworth 04-23-2015 08:07 AM
I recently acquired a tail from EASY in Emeryville, CA (that had been lying around for many years because it had been damaged by a rear hit) for my Carrera 3.0 RS clone project. It has a p/n 930 512 010 00 with no indent for the wiper motor, but it also has license plate cutouts that seem to be stamped, not cut by hand. Could this tail have been made using left over '73 frames with license plate cutouts...in MY74?
Does anyone have period documentation showing the p/n for the 3.0 RS tails? Later documents show the 3.0 RS tail having a 911 rather than 930 p/n, but many parts on the 3.0 RS used the 930 numbers. There are period pics showing both non-small-grill tails like the C3.0 and 75 2.7 Carrera used (which have a 911 p/n), as well as many with the small grill which would have had a 930 p/n. Many more of the restored 3.0 RSs have the small grill.
Does anybody know when the first use of the 930 512 010 00 p/n began? The early turbo prototype appeared at the Paris show in Oct. 74, so most likely a 930 p/n tail would have been used by then.
If this tail had been used on a pre 74 long hood 911 the license plate light cutouts could have been done by a very skilled body man, and the lights could have been removed later as there were no license lights on the tail as acquired. It has some rust issues and the damage from the hit, but it appears to be repairable. I may cover the cut-outs with small plates, but will not try to cover them with bondo.
http://forums.pelicanparts.com/uploa...1429800555.jpg
http://forums.pelicanparts.com/uploa...1429800578.jpg
http://forums.pelicanparts.com/uploa...1429800609.jpghttp://forums.pelicanparts.com/uploa...1429801548.jpg
group911@aol.co 04-23-2015 08:13 AM
How about another shot of the front of the center mounting bar?
onboost 04-23-2015 08:14 AM
Anyone have a decent rubber lip for this style tail? I think I prefer this li as opposed to the later style on my 930. Hmm, wont be correct but who cares!
PM me
Thx
http://forums.pelicanparts.com/uploa...1429802047.jpg
Gib Bosworth 04-23-2015 08:23 AM
The tail is at the body shop now so can't take more pics for now...will post later showing better how the latch bar is glassed into the tail. Here is one Jim at EASY took, but still not enough detail on the latch bar attachment. It does show the damage from the hit...which I was able to remove somewhat before taking to the body shop.
http://forums.pelicanparts.com/uploa...1429802520.jpg
Gib Bosworth 04-23-2015 09:25 AM
It just occurred to me that a pre 74 frame would have had a 911 number stamped on it somewhere. Anyone know where the pre 74 lids had a number stamped...and what the number was?
Gib Bosworth 04-23-2015 09:35 AM
I just went to the 930 Turbo 3.0 website and found this bit of history note:
930 Turbo Carrera 3.0-liter: Registry
Chassis # Last Known
Location Color Notes
1974
911 330 0157 USA Silver Prototype Turbo with RSR flares, built on a 1973 911S, with a non-working mocked up engine at the 1973 IAA Frankfurt motor show and 1973 Paris Motor Show
I thought the prototype was first shown in 74...so this keeps the possibility open that the frame on my lid was left over from the pre 74 MY.
But maybe I am just being a little overboard with the possible scenarios.:rolleyes:
Gib Bosworth 04-23-2015 10:25 AM
Here are some pics of the 930 prototype that was shown in fall 73 at Frankfort and Paris shows, plus some of the car at an unknown location. The latter pic clearly shows the car without the small grill, but the Paris show pic seems to show it with the small grill, but not sure. The restored car clearly has the small grill tail on it.
This car, although built on a 73S chassis was essentially the same body work as the IROC (also 3.0 RS) cars that began racing in fall of 73, except the IROC cars shipped with ducktails but raced with all wide FG tails. The prototype 930 and 74 3.0 RS would have been the first cars with this type of tail with a rubber lip, although the 74 MY Euro Carreras also used these at some point I think.
http://forums.pelicanparts.com/uploa...1429809494.jpg
http://forums.pelicanparts.com/uploa...1429809544.jpg
http://forums.pelicanparts.com/uploa...1429809589.jpg
http://forums.pelicanparts.com/uploa...1429809715.jpg
http://forums.pelicanparts.com/uploa...1429809750.jpg
kristof 04-24-2015 04:56 AM
And if it's not in that spot , can you look around the tails hard. The 930 part number units had to be stamped somewhere , just as the 911 part number units seem to be.
Can people who have these (non 2nd grill) check for stampings also. And if you find a part number stamped , also report the single digit AFTER the triangle logo.
Thank you all in advance.
Hello.
I have a whale tail with part number 911.512.010.07 + triangle + K. It is a metal frame with rear wiper indentation. The part number is located on the centre frame where the lock is attached. It is SINGLE grille !
I'm prepared to sell it. It is in good condiition, some surface rust, nothing serious. Located in Belgium / Europe.
sp_cs 04-24-2015 05:23 AM
If anyone has any thoughts on this I'd appreciate hearing from you.
Alternatively is it safe to run this spoiler without the heat shield?
Gents, I've just acquired a small vent tail with part number <a href="tel:911.512.010.07">911.512.010.07</a><br>
<br>
I'm looking for confirmation on the heat shield part number as this is missing - <a href="http://forums.pelicanparts.com/porsche-marketplace-discussion/562316-value-1976-2-7-carrera-10.html#post5832789" target="_blank">from a separate thread,</a> I noted the following part numbers for the heat shield - I'm assuming the 3rd one listed?<br>
<br>
Non 2nd grill , Non A/C optioned - <a href="tel:911.512.165.00">911.512.165.00</a><br>
Non 2nd grill , A/C optioned - <a href="tel:911.512.165.01">911.512.165.01</a><br>
2nd grill - <a href="tel:930.512.165.00">930.512.165.00</a><br>
<br>
Can anyone confirm pls?<img src="http://forums.pelicanparts.com/uploads24/image1420330404.jpg" border="0" alt="">
Gib Bosworth 04-24-2015 02:03 PM
Here is a shot of the underside of the latch brace attachment. These were attached in many different ways it appears.
Also shown is a ducktail from a factory US 74 Carrera that has license cutouts plugged with small plates attached with screws. This tail was made near the end of the MY run of US Carreras (0524), which would indicate that the factory was using up old stock of steel frames from the pre 74 long hoods well into the 74 MY. So it is possible that my red whale tail cutouts were done by the factory from 'left over long hood frames'. I will make plates to fit under the cutouts like the factory did.
http://forums.pelicanparts.com/uploa...1429909136.jpg
http://forums.pelicanparts.com/uploa...1429909199.jpg
http://forums.pelicanparts.com/uploa...1429909283.jpg
group911@aol.co 04-24-2015 06:26 PM
I would run the one without a/c as there was no a/c condenser up near the second grill unless it's the larger second grill. I don't think there is a problem running without the protection shield but you may as well buy one as they are only about $200
group911@aol.co 04-24-2015 06:34 PM
How can you tell it was made near the end of the US Carrera run? US Carrerra's never had the large or small second grills as far as I know.
The fiberglass work certainly looks factory. Is the second grill the same size as the factory unit? The cutout doesn't appear to have the correct hole layout to mount the second grill.
Is the support for the center bracket spot welded?
Gib Bosworth 04-24-2015 07:45 PM
Bob,
The 74 Carrera has a DUCKTAIL not a whale tail...my point was that since the factory was using pre 74 steel frames with cutouts for the ducktails, they could have used them for my whale tail. The pic is from US Carrera 911 440 0524, which is the 5th from the last US Carrera coupe built...later in the model year.
The pic of the latch support is of my RED whale tail shown in the other pic...it's just a lousy color reproduction...not sure why.
group911@aol.co 04-24-2015 08:17 PM
Originally Posted by Gib Bosworth (Post 8593659)
Bob,
So you are referring to the tail on the white car.
On that picture of your latch support, it's a pretty good shot of the second grill backside but I'm not seeing all the holes for the grill. The fiberglass work looks factory. Can you see if the unusual support bracket is spot welded?
sp_cs 04-27-2015 12:54 PM
Thanks bob, I think that part may be NLA, so will keep a lookout. I see that the 3rd part number is still available so may try this one.
