Smart quod bastardus
fredmeister's Avatar
front strut insert rocking freeplay-question
I am removing my Bilstein front strut inserts to get revalved for new T-bars and did a check on wear before removing them from the strut housing.
I have some slight rocking of the strut insert due to clearance with the upper bearing and seal in the strut housing and wanted opinions on what was an acceptable or expected amount of freeplay here?
There has to be some radial clearance between the strut insert and the upper strut bearing which would allow a little rocking movement between the 2 parts but never having seen a new strut to compare to I want to get an idea if I need to send my strut housings out for replacement of this bearing.
----Fred
1979 930 Turbo....3.4L, 7.5to1 comp, SC cams, full bay intercooler, Rarlyl8 headers, Garret GTX turbo, 36mm ported intakes, Innovate Auxbox/LM-1, custom Manually Adjustable wastegate housing (0.8-1.1bar),--running 0.95 bar max
---"When you're racing it's life! Anything else either before or after, is just waiting"
Old 02-24-2010, 08:57 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Fred,
These bushings do wear out. I have a handful of friends who've had to replace these. Clint at Rebel Racing does the replacement, but he's pretty busy these days.
Send Craig Garrett at G2 Performance a pm (username here = cgarr) for his input on acceptable clearance/wear and he'll shoot it to you straight. He provides replacement service and and he can get them turned around for you quite quickly. He and his brother Denny, also on Pelican, are local friends in MI and great guys who really know their stuff.
Kevin L
'86 Carrera "Larry"
Old 02-24-2010, 10:14 AM
fancytown
cgarr took care of re-bushing my strut inserts. Real fast turn-around time.
all cars sold.
Old 02-24-2010, 12:14 PM
Max Sluiter
Flieger's Avatar
Clint is doing a run of struts right now. I saw them at the machine shop last Saturday.
Nice pieces, offset ball joint attachment for more camber, raised spindles, de-cambered spindles,... Excellent welding on the Aluminum.
Old 02-24-2010, 02:07 PM
