Rear side marker bulb replacement help
I feel like a retard.. but how the heck do you get at the socket.. the reflector thingy seems to be bonded to the whole assembly.. this is for my 76.. Im lost.. do I need to remove the whole thing??
JP '76 911s Ice Green Metallic bone stock |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Unscrew the two screws, and pull the lens off of tailight assy. If it has been on there for a long time, you may need to pry VERY gently to remove the lens. Good luck, Gerry
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
This is behind the lens... its the sidemarker light which is hidden behind a reflector..
Recreational User
It's held in there by a spring clip on one side. The clip is about 1/4" wide. If you push it in the direction away from the lens, it will free it. In fact, the best way to get it out is to use a flat-bladed screwdriver to pry the OTHER side out. The prying action presses the spring clip enough that the whole thing pops out. It should happen easily.
