Radio noise
I just replaced the Blau stock radio in my 87 carrera and I have a constant whine and static in the speakers even at no volume. Is there a filter of sorts to install or another approach to the problem.Idon't recall if the old set had that problem since I seldom used it since purchase. Thanks for your reply
Old 03-09-2010, 08:06 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Assuming that this noise is new to your your installation, you might check for a proper ground as per the installation manual.
Just ground the case to the chassis.
Plug wires can cause these symptoms.
Good luck,
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 03-09-2010, 09:08 PM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
You can get a noise eliminator at Radio Shack or similar place.
It looks like a small tin can with a wire at each end (or terminal) with the center of the can having a tab with a hole to bolt the unit to something metal and grounded.
Inside the can is a coil and capacitor, and this is what shorts the noise to ground,
They are rated for current (amps) so get one that is big enough to do the job.
This unit goes into the power line just before the radio, as close as possible.
Hope this helps
Bob
Bob Hutson
Old 03-09-2010, 10:14 PM
Thanks all, I'll try the ground first and then the filter.
Old 03-11-2010, 05:24 PM
a.k.a. Kevin M.
ghost1001's Avatar
if you rev the engine will the tone of the whine change? If so you are getting a type of feedback from the alternator. We used to get this noise all the time when installing big amps back in the day.
If this is the case the "filter" you are looking for is a "ground loop isolator", anyway that is what we used 20 years ago, i bet not much has changed.
Kevin
Best turbo ever built SOLD.....
Looking for a Porsche with 4 seats......
Old 03-11-2010, 05:28 PM
dshepp806's Avatar
I bet the filter won't do the trick,..let's see.
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 03-12-2010, 03:42 AM
I developed noise after MSD install
I then used the the $40 MSD noise filter to clear it
if the noise just happened one day out of nowhere i usually go after rebuilding the alternator to start track down
in this thread's case i'd start by fixing the radio
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-12-2010, 09:44 AM
dshepp806's Avatar
ground plane on the radio has to be right (first)...RoninLB's point is well made...first things first.
Doyle
Middle Georgia
Old 03-12-2010, 12:15 PM
Had precisely the problem you mention, when I installed a new Sony radio in my
'80SC. Went to Radio Shack and bought the "radio noise filter". I installed it in the 12V pwr line to the radio. Voila!! noise all gone. Don't make it more difficult than necessary. It seems the noise signal is riding on the 12v from the alternator. At least thats my thought. Give it a try, as it's pretty inexpensive!
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 03-12-2010, 12:26 PM
nineball's Avatar
Doyle
x1000 check and double check the ground for your radio first.
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 03-13-2010, 11:22 AM
